Wism Supports Hybrid Mode?
sbeauton
I'm wondering if any ones knows if the WISM blade supports Hybrid Mode on a 6509 or is Native Mode the only way to run WISM. Thanks in advance
ankbhasi
Hi Friend,
WISM blade is not supported in Hybrid mode and Native mode is the only way to make it work in 6509 chassis.
It requires at least: 12.2(18)SXF2 and later.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp2856861
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Friend,
Ankur
