wism2 in cisco 6500 switch
In our one project there is one guest Network
we are using two wism2 controller in cisco switch 6500 series.and in  cisco Acess switches  are in floors in which cisco 1040 with integrated Antenna
for 1040 access point in switches the port should be trunk
first we have to create service port ip add
and then management add for wism and these two ip add should be in different subnets.
and the additional steps in 6500 series for wism controller
wism module number controller 1 allowed-vlan range
and the management vlan be native vlan always
for two wism2 module how to make  redundancy for two controllers
please guide the correct steps for implementation
2 Accepted Solutions
Sandeep Choudhary
Hi Syed,
check this link:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/wism/technical/reference/appnote.html
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/catalyst-6500-series-7600-series-wireless-services-module-wism/112968-wism2-deploy-guide-00.html
*** If APs are in local mode then make sure that switchport must be in access mode.
Don't forget to rate helpful posts
To configure primary and Secondary on AP:
You must login to wlc where AP is connected,  then click on Wireless > All APs, click on specific AP. Go to High Availability Tab and enter here prim/sec WLC ip and name.
More info: http://mrncciew.com/2013/04/07/ap-failover/
1040 is bit old model: Uses 2x2 multiple-input multiple-output (MIMO) with two spatial streams, More Info: http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1140-series/data_sheet_c78-609338.html
2602E is newer model : uses 3x4 multiple-input multiple-output (MIMO) with three spatial streams: http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2600-series/data_sheet_c78-709514.html
Dont forget to rate helpful posts
Sandeep Choudhary
Hi Syed,
check this link:
Thanks Sandeep.
After configuring the Wism modules we can access the web of these two controller 4404.
Could you please explain steps  how to make primary and secondary controller for the Acess points 1040.
And in our project we are using one more controller 5760 model and we are using Acess points 2602E model.
Could you please explain the difference between these two Acesspoints .
1 1040
2 2602E
