WLAN - Clients reconnect / not all get IP address
Nirak160797
Hi All,
I am wondering whether the behavior I observe in a WLAN I set-up is ok or whether any settings might be wrong.
I have set-up a WLAN in vWLC that is supposed to only work on 5 Ghz. (vWLC see image - System Info)
I have 10 clients which connect to this WLAN.
  • II see that the clients reconnect after very short periods - very short uptime (see image clients).
  • Furthermore not all of them get an IP Address - see image Client IP.
Is that a normal behavior or is supposedly something wrong the the WLAN configuration?
Kind regards,
    Karin
marce1000
 - Use client debugging for a particular mac, which you can have analyzed with :
           https://cway.cisco.com/tools/WirelessDebugAnalyzer/
 M.
