How to see RSSI on WLC? Trying to adjust directional antennas for aironet bridge mode.
mikenewcomb
Hello all, I'm installing a pair of 1572 aironets in bridge mode to connect a remote workshop to my network. Bridge only, no clients will connect. When adjusting the directional antennas, how do I see signal strength in real time to get the best connection?
TIA
if they are in "Root Bridge" & "Non Root Bridge" mode, then you can use "show dot11 association <mac_addr>" CLI output to verify RSSI/SNR
Rasika
*** Pls rate all useful responses ***
I tried that but it was not accepted on either AP or the WLC CLI. Maybe an different code or something?
