wlan connectivity
ahmedalshami
Level 3
Level 3
Dear
i have 3 building in the first and second building i used integrated switch with controller .if i use bridges 1310 to have connectivity between main building and the two buildings .do the LWAP and integrated controller will transfare the data to the main building by using the wireless connectivity
thanks
please advice
Amit Singh
Ahmed,
You can get the wireless connectivity betwenn the buildings but in this case both the data and the control traffic will flow all the way to the controllers and controller will decide to forward the traffic to the destination.
-amit singh
thanks
so if i put WCS (wireless controler system) in the main building it will work ?
