Wlan Controller 2500
mhuaynate
Level 3
Level 3
Hi my friends:
Its posible to implement feature H-reap in wlan controller 2504 with iso version7.2.103.0, because i dont have this option in my wlan controller.
thank.
Marco
5 Replies 5
Stephen Rodriguez
in 7.2 code and beyond, the feature is renamed to FlexConnect.
So you would check the FlexConnect Local Switching box in the WLAN and the AP mode to FlexConnect
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thak.. so much my friend.. i found it. the way to configuring FlexConnect is the same h-reap ?
that is correct.
HTH,
Steve
HTH,
Steve
Muchas gracias amigo!
Abhishek Abhishek
As per your query i can suggest you the following solution-
Yes it is possible to implement feature H-reap in wlan controller 2504 with iso version7.2.103.0.This is known as flex-connect.
For more details on how to configure flex-connect please refer to the link-
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_flexconnect.html
Hope this will help you.
