WLAN isn't working with indoor ROOT AP and MESH AP
Wellington L
I'm using one Virtual Wireless Lan Controller and one SSID configured.
I enabled the WLAN but it isn't working with the ROOT AP and MESH AP.
I configured the ROOT AP and MESH AP and they are with the radios UP and i can access the MESH AP.
I enabled all configurations in the MESH page in Wireless page in the Controller.
I'm using the EAP to authenticate all Access Points and i put them mac-address in the security --> Mac-filtering --> Any WLAN.
My AP Group is default-group and the Access Points are there, the SSID is enabled and broadcasting.
Will i need more configuration or is this a limitation from Virtual Wireless Lan Controller ?
Thank You.
2 Accepted Solutions
Scott Fella
Well that looks good... I'm really wondering if it does support indoor mesh as I know it supports the outdoor mesh only on FlexConnect mode. Maybe it's something you need to ask TAC. Maybe it is supported but broke:).
-Scott
Mesh mode is an variant of Local mode it won't be supported by vWLC. will've the RNE corrected.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74.html#wp973325
16 Replies 16
Scott Fella
I don't thing MESH is supported on the vWLC.
-Scott
If it is outdoor mesh , it is not supported else it should work
These APs are indoor and i configured one with ROOT AP and another with MAP and i disconnected this MAP from the network after configuration and i turn on this without ethernet connection and this connected with the ROOT AP nornally and i can see it in the WLC and i can reach it from the wired network to ping and access using SSH.
But the radios are UP in the two APs and the 5Ghz are closing the link connection between the ROOT AP and MESH AP but the 2.4 GHZ is UP but isn't broadcasting any SSID in both.
Scott Fella
Okay so they are indoor APs. So now, what exact model and please post your show WLAN and a show ap group summary.
-Scott
I can see this error in the MAP and ROOT.
*Mar  5 12:05:05.897: %LWAPP-3-CLIENTERRORLOG: Delete VAP: received a delete request for an invalid WLAN ID 1
The APs are 1142N. My Virtual Wireless Lan Controller is in the 7.4 version, i tried with the 7.3 and it didn't work and now i tried with the 7.4 and continue not working.
Thank You.
Just quick question, are you able to see the SSID on the wireless clients or not ?
If you are able, your clients are not able to connect, right ? If that is the case, please
have the output of :
debug client < mac address of the client >
I can't see it in the client.
In the debug client, nothing shows.
Yeah... maybe it's just broke. I have only used the vWLC with FlexConnect and that is really it. Not as stable as a WLC but it is what it is.
-Scott
Yes, me too.
I just used the vWLC with the FlexConnect mode, this is the first time that i'm doing a LAB like this.
Scott Fella
-Scott
Ok Scott, i will contact TAC and after i post the answer here.
Thank You.
Keep us posted!
-Scott
Any luck?
