wlan mismatch
David James
Community Member
I am running Prime 1.4 to manage two 8510 WLC's both running 7.4.110.0  but there is a mismatch on the audit status between what Primes says the WLANS that an AP has vs what the controllers has.  I know that the controller takes precedence but I can I fix this issue so that my controllers and Prime agree on the WLANS assigned to the AP's?
Sandeep Choudhary
Who is showing the correct VLAN.... WLC or Prime ??
If WLC is correct then Clcik on mismatch in prime infra and then select Refresh config from Controller.
Dont forget to rate helpful posts
