WLAN override to activate disabled WLAN?
with_joerg
All,
I have three SSIDs/WLANs and 100APs. Now, one of the WLANs is a guest-WLAN which should only bee seen on 16 out of 100APs.
If I enable the guest WLAN globally then I would need to apply the WLAN override template to all APs and then I would need to reset all APs.
Q: Is it possible to leave the guest-net disabled then select it in the override template for 16APs and apply it to those 16 APs only? Will these 16APs then beacon the guest-SSID although it is globally disabled (in the WiSM)?
--Joerg
dennischolmes
Level 7
Level 7
If the SSID is disabled you should not be broadcasting it over the APs.
