WLAN Peer2Peer Blocking
rgmamaril
Hi All,
Good day!
I would like to ask for your expertise regarding peer2peer blocking. We are currently running version 8.0.140.0 on 5508 WLC. peer2peer blocking is enabled on WLAN but wireless client on the same WLAN can still ping each other. Would like to know if there is resolution for this. Thank you.
Rey John Mamaril
8 Replies 8
Sandeep Choudhary
HI,
It should be set to DROP .
Info: The Peer-to-Peer Blocking feature blocks communication between two clients on the same WLC (option drop) on a WLAN.
Dont forget to rate helpful posts
Hi Sandeep,
peer2peer is set to drop but still ICMP persist on both wireless client on the same WLC. Please see attached file.
Thank you.
Sandeep Choudhary
AP are in flexconnect mode or local mode ?
is it slocal switching enabled 802.1x WLAN ?
Hi Sandeep,
APs are in local mode.
Thank you.
Is this across multiple WLCs ?This feature works for clients on same WLC!!
Didn't this always work, if the network gateway is going to route the packets. Are the clients in the same layer2 network?
Hi Sandeep,
clients are on the same WLC.
Thank you.
If you have only one WLC, AP connected it with local mode , Clients are in layer 2 network and P2P is set to drop then it must work.
Open a TAC case!!!
