Wlan Survey Signal Strength, SNR and DBM explained
Does anyone know of a simple explanation of what signal strengths are required for wlan, SNR values and Dbm etc etc that doesnt look like a Harvard professor wrote it.
8 Replies 8
George Stefanick
I might also suggest www.cwnp.com as a source of information.
I will check them both out
You're looking for specific values? Or are you looking for explanations for terminology?
Values:
-67dBm (SNR 30) for voice at 54Mbps
-72dBm (SNR 25) for data at 54Mbps
These are 2.4GHz values. I believe the SNR needs to be a bit better for 5GHz implementations.
Jeff,
I must be incredibly stupid I constantly get the values mixed uop and cant remember if its a high SNR or Signal strength thats better.
I was looking at my Ekahau site survey real time network results and thought the values looked odd, then I realised i couldnt remember which one is meant to be high for good and low for bad.
Basic stuff I know
Mick
An easy way to remember:
Signal - The lower the dB value the louder the signal
-30 Is right on top of the AP
-50 Is 20 feet or so
-70 Is 50 feet or so
Noise - You want on the other end
-100 Is no noise
-95 means there is -5 dB of noise
-90 means there is -10 dB of noise
SNR
Is signal minus noise. The HIGHER the value the better. Most voip is designed around -25.
Hope this helps...
It does thats exactly what i wanted clear and precise
many thanks
mick
The higher the SNR the better.
You can derive the data-rate from the SNR.
On an IOS AP you can issue the
"show controller dot11radio<0|1>" command.
There you will see, what data-rate the AP will use for what SNR. With this information you can conduct a good site-survey.
For example:
A Cisco AP will use 54 MBit/s if the client is seen better than 31dBm SNR.
With an SNR of 19dBM - 18MBit/s are possible.
