WLANs disabled after power down
cawst
We had a power outage coupled with a UPS issue, and our wireless controller (WLC 2504) lost power.  When the power came back everything seemed to reload fine - it found all of the APs, etc... - but the WLANs remained disabled until I enabled them manually.  Is there any way for these to not automatically disable after the controller is down?
what software code you run on your 2504 ?
I was a bit downlevel (forget off the top of my head now - 7.something?)  Hadn't occurred to me it might be a firmware thing - figured it was just an option somewhere.  I've updated and will keep an eye on it.  So, I'm guessing that it's not a settable option, given your response?
