WLC 2504 and Linksys Managed Switch
ryan.fauzi
Hi, I had a problem connecting cisco WLC 2504, mikrotik, and Linksys Managed Switch.
1. vlan untagged on WLC management interface.
2. DHCP Server on mikrotik. I also set this up for WLC DHCP Server and default gateway.
3. I plugged in the WLC and AIR AP3502i on Linksys Managed Switch, I set trunk port for WLC and Access port for AP.
4. From Linksys Switch there's interface to mikrotik (configured with trunk)
5. On mikrotik to Linksys Switch is bridge_Vlan interface (many vlan here)
Conditions :
1. AP Joined, but I can't get IP address when connecting to SSID
2. All device can ping each other
3. I also have set capwap primary controller for AP
4. I don't know if there's option 43 config on linksys switch
From the case above, anyone can give me suggestions?
Masato Ueoka
HI
What is interface for your WLAN is it management interface or Dynamic interface?
Do you config Primary DHCP Server to milkrotik and DHCP Proxy Mode is on ?
@Masato Ueoka wrote:
HI
I used management interface for wlan
yes i config dhcp primary to mikrotik and dhcp proxy is global
is it problem?
That's fine.
you have 2 option
1. disable DHCP Proxy to passthrough client dhcp packet to mikrotik.
2. WLC debug dhcp packet to see exchange of DHCP packets to isolate the problem.
