02-25-2014 09:28 AM - edited 07-05-2021 12:16 AM
02-26-2014 08:07 PM
Hi all,
Please see attached pics.
It still doesnt get the IP address when connected to the WLAN
02-26-2014 08:11 PM
Open the Vlan 20 interface and make sure you have the DHCP server IP address as the primary DHCP.
02-26-2014 08:19 PM
Hi Scott,
Already put the DHCP address but unable to get it
02-26-2014 11:14 PM
Where is the gateway IP address ????
Please use the gateway IP address under management interface.
Dont forget to rate helpful posts
02-27-2014 12:16 AM
U mean put in 10.154.101.104? Correct
02-27-2014 01:05 AM
no the gateway must be in vlan 120.
Just see yout management interface configuration page.
VLAN IDENTIFIER
IP ADDRESS
MASK
GATEWAY: Just enter the IP address (Which you assigned the I for vlan 120 on switch or firewall).
03-02-2014 11:22 PM
Inside MGMT int, the gateway i put in 10.154.101.104 but it said "invalid address information provided". i change the subnet to 255.255.255.0 i can put in 10.154.101.104
03-02-2014 11:38 PM
I think the gateway must be in vlan 101.
03-03-2014 02:43 AM
i put in the IP 10.154.101.1 still unable to receive DHCP.
Do my setup have problem somewhere?
03-03-2014 02:56 AM
try to tag the management vlan with 120.
place vlan identifder as 120 on management interface.
also paste the screenshot for APNMM ssid wlan.
02-25-2014 09:48 AM
Thanks for ur fast respone,
Q: 1,2,4,5 understand
Vlan 120 is actually already exist.
WLC to be configured as 10.154.120.231
By your recomendation, at WLC create VLAN 120 and set IP as 10.154.120.231, is it?
then what should the IP for management interface? any IP?
02-25-2014 09:55 AM
If you're not using 10.154.120.231 with other device. of course you can use it. For me the best way is have the AP's and the WLC on the same vlan, like your picture as well.
02-25-2014 10:02 AM
The WLC is connected to an access vlan 120, so you just need to make sure vlan 120 is being passed on all switches. The wlc port can be an access port, but if you want to use multiple vlans and put users on a different vlan, then you want to trunk it. Best practice is not to use the native vlan and to actually tag the management. You don't need to have vlan120 interface created, because the management already on that vlan. You create dynamic interfaces if you want to place users on a different vlan than 120.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-25-2014 10:34 AM
If vlan 120 is already exists then just connect WLC to port(trunk- when u need more then 1 vlan to allow) and configure management ip as 10.154.120.231.
What is the ip of vlan 120, it must be diff from wlc management IP.
03-03-2014 02:58 AM
i did try to tag the management vlan to 120 but once i do that, i will lose connection with the WLC.
can't ping, or GUI to the WLC
