WLC 3504 can't connected on web based controller after setup wizard
Reedho
i just bought a WLC 3504 device, after completion at the process setup wizard. then i can't enter the web based controller stage, with ip management that i have set.
how can i enter this section.? for the switch i have set it to trunk mode
Rasika Nayanajith
If you set a vlan for management interface in initial setting make sure it is not the native vlan on that trunk port.
with that you should be able to ping/GUI access the wlc.
Rasika
5 Replies 5
Rasika Nayanajith
Rasika
I have successfully trunk the port, and can ping but still can't access the GUI, is there something wrong with my setup wizard?
Console into the wlc and make sure you can ping the gateway from the appliance. You are also trying https correct.
-Scott
Did you try https://192.168.10.10 ?
If not try that
Rasika
Solved
by changing the native vlan according to the existing trunk vlan and access https://ip address
Thanks @Rasika Nayanajith
