WLC 4400 and 5500 Fail-over
ceracaza08
Can we do the same thing with WCL 4400 and 5500 series for failover? We have 1 existing 4400 WLC and we wanted to purchase another 1 for fail-over as well as backup. But right now, 4400 is EOL already. The only option is to have the 5500 WLC.
So if you do have previous set-up like this, so I would need your inputs.. Otherwise, same as usual, will gonna test to work this out.
6 Replies 6
Scott Fella
You can have both in a primary and backup, but make sure they are on the same code version. I'm assuming that you also have the configuration correct for the two wlc to communicate.
I would put them both on the 7.0.220.0.
-Scott
Hi Scott, thank you very much for your prompt response. I will keep you posted if I do encounter some issues.
Sounds good.
-Scott
Hi Scott,
Just would like to ask some verification from your end. Is NCS a replacement for WCS? or it's just another piece of software that is built from WCS platform?
NCS replaces the WCS.
NCS comes in two "flavours":  VMware and appliance
Hi Leo,
Ah.ic..Thanks much for your prompt response...Keep it up.
