Showing results forĀ
Search instead forĀ
Did you mean:Ā
WLC 5508 AP AIR-LAP1142N-E-K9 and android clients issues
tanner.zaitt
Level 3
Level 3
Do you aware of any issues with Android clients?
My WLC is 5508 and the AP is LAP1142N-E-K9.
The SSID is open without security for public wifi.
The DHCP server is on Microsoft Windows Server with Routing and remote access features enabled.
The Android devices are not able to browse internet.
They connects successfully but without internet.
On the same AP Iphone smartphones and standard Laptop machines have internet.
The issue is only with one AP in the infrastructure, other APs are okey.
Do you have any ideas where is the problem?
Thank you in advance.
Rich R
Do you have the same tcp-adjust-mss setting on both WLC?  Try 1250? (This is something where I've specifically seen Android behave differently to iPhone and Windows previously)
22 Replies 22
Leo Laohoo
Using CLI, look at the client detail & determine if the wireless have the correct IP address, subnet mask and default gateway?
Can the affected wireless client browse internal address?
The network parameters are correct.
I am not able to check your second question remotely.
marce1000
  >...The issue is only with one AP in the infrastructure, other APs are okey.
              - Reboot the access point . check if that can help.
M.
One Correction, all APS are affected on the second controller.
The first controller is okey.
The controllers are individual, they are not in HA configuration.
We tried to reboot all APs on the controller without positive effect.
Issue only with android devices.
        - Can all the access points join the controller again after reboot (please verify).
 M.
Yes, the operational status is REG (Registered).
 - Use latest software version that the 5508 can (still) run (if applicable) : https://software.cisco.com/download/home/282600534/type/280926587/release/8.5.171.0 (it can't go beyond that). Check if that can improve the situation with the Android clients.
 M.
tanner.zaitt
Level 3
Level 3
I did see only that a 10 days ago the wlc controller with issues has been rebooted unexpectedly.
Rich R
Where do you apply this setting tcp-adjust-mss 1250?
(Cisco Controller) config>ap tcp-mss-adjust enable AP3 1250
Hi, thank you.
This setting looks like solving the issue.
Should I implement it to all Access Points?
Reboot of the Access Points is it required?
tanner.zaitt
Level 3
Level 3
With Tablet with Android 8.1 doesn't work.
Open network without protection for free access.
I noticed my previous configuration:
(Cisco Controller) >show ap tcp-mss-adjust all
AP Name TCP State MSS Size
A-AP1 disabled -
B-AP1 disabled -
C-AP3 enabled 1363
D-AP1 disabled -
E-AP2 disabled -
F-AP2 enabled 1363
G-AP1 disabled -
H-AP2 enabled 1363
I-AP3 disabled -
J-AP7 enabled 1363
H-AP2 enabled 1363
TB-AP4 enabled 1363
NT-AP8 disabled -
UL-AP10 disabled -
PL-AP9 disabled -
TA-AP1 disabled -
TF-AP1 disabled -
TJ-AP1 enabled 1363
TB-AP5 enabled 1363
--More-- or (q)uit
NN-AP1 enabled 1363
AB-AP6 enabled 1363
RP-T2 disabled -
TD-AP4 enabled 1363
TA-AP1 enabled 1363
Do you have information for 1363 size?
Rich R
The Cisco recommendation has changed a number of times over the years and they now recommend 1250.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/global_traffic_forwarding_configurations.html#tcp-mss
We enable 1250 for all APs now for maximum compatibility and haven't had any reports of problems with that setting whereas with higher values we did.
If that still doesn't work for some devices suggest you do a packet capture to determine why.  You'll often find the problem is with certificate exchange on TLS connection setup where the packets are inevitably using the max MSS value.
Thank you for your explanation.
My colleague finds this in the logs of the controllers:
*apfMsConnTask_1: Aug 02 12:11:27.729: %LWAPP-3-INVALID_SLOT: spam_api.c:1469 The system detects an
invalid slot identifier (1) - All the AIDs are in use. Could not allocate association identifier; AP 5c:50:15:1d:3d:b0
Field Notice: FN - 70253 - Wireless Client Fails to Associate: AID Error - Software Upgrade Recommended - Cisco
The controllers are with version: 8.0.152.0.
As you see 8.0.150.0 and 8.0.152.0 are affected.
Are you recommend to jump to version 8.2.170.0 ED?
