WLC 5508 formatted flash
chawkideeb
Dear Support ,
After formatting the whole flash of a 5508 WLC , and even when we tried to upload new image via bootloader , the wlc restarted and the bootloader immage appear again.
is there a way to upload an images so the wlc can start normally or we dont have any other choice then opening a cisco TAC case , so the enginner can send us the RTOS file or RMA the WLC?
Thank you for your support.
best regards,
chawki
2 Accepted Solutions
Scott Fella
You need to open a TAC case and get the appropriate files and procedures.
-Scott
Only TAC has the proceedure to recover from GRUB.
6 Replies 6
Scott Fella
-Scott
Hi ,
Thank you for your confirmation.
Is there a chance to get these files and upload new image without opening a TAC case , since we do not have smartnet support on the device.
Best Regards,
Chawki
well received...
Thank you
I am currently in the same situation. Can you tell me how I solved this problem?
Hi ,
You will need to open a cisco TAC case to RMA the WLC.
