WLC 5760 local webauth problem in iphone
chunyuan.huang
I am try to use the local webauth by Cisco 5760
In the NB,MAC,Android it can authentication , but when i use iphone to test the webauth
When I enter the username and password and submit , iphone just only white screen , it does not show authentication success
What is my problem
My webauth config
aaa authentication login local_webauth local
aaa authorization network default local
parameter-map type webauth global
 type authbypass
 virtual-ip ipv4 1.1.1.1
parameter-map type webauth test
 type authbypass
wlan Web 1 Web
 client vlan VLAN0100
 no security wpa
 no security wpa akm dot1x
 no security wpa wpa2
 no security wpa wpa2 ciphers aes
 security web-auth
 security web-auth authentication-list local_webauth
 security web-auth parameter-map test
 session-timeout 1800
 no shutdown
6 Replies 6
Scott Fella
After you get the blank white screen, are you able to access the wireless or not.  I ask this, because its either an issue with the success page or maybe and issue with the portal page.
-Scott
When I get the white screen,the iphone did not access the wireless
But i use another device ,like win7 or android it can work fine
I experience the same problem. We are using a Cisco WLC 5760. Did you guys have any luck solving this issue?
Thank you.
Web-auth redirect failed with IPad/IPhone 8.0/8.1 for pop-up window
CSCus05550
Symptom:
The Customer got the blank page after typing the username and password with safari pop-up window.
Conditions:
IPad/Iphone 8.* with pop-up window.
Workaround:
Using safari without pop-up window or third party browser which can work fine
Further Problem Description:
My testing topology:
Internet---------------Firewall-------------------SW---------------AP-----------------------IPad
10.140.246.32 192.168.100.1 192.168.100.2 192.168.100.9
gmit
I am having the same problem, has anyone heard of a solution.
Viten Patel
wondering if you have tried following
http://www.cisco.com/c/en/us/support/docs/wireless/5700-series-wireless-lan-controllers/117728-configure-wlc-00.html
what code are you running on 5760
