Cisco 5760 and Branch APs
mcaoile
Hi experts,
I am installed two Cisco 5760 and local APs have joined the WLC.  The customer has 13 branches with 3 APs each branch.  The code of the 5760 is on 3.3.4.  I have read that the 5760 does not support flexconnect mode.  How do I configure these branch APs to join the WLC?  Is there any configuration template that I can follow?  DHCP sever is located centrally.
Manuelito
2 Accepted Solutions
5760 only support local mode AP at the moment.
So you cannot locally terminate branch wireless traffic, every thing has to come to the central WLC.If you want you can create AP group per branch & give different subnet for each branch wireless users defined at your HQ switch network.
Rasika
**** Pls rate all useful responses ****
you need to open udp 16666 and 16667
Rasika
Hi Rasika,
Are there any ports that should be opened in the firewall?  I just have to define dynamic interfaces for each branch in the 5760?
Manuelito
