wlc 9800 flexconnect Clients stuck on IP Learn
Leo TI
Hello everyone, I have a vWLC9800 17.9.4a, in a flexonect scenario, the clients do not get an ip,
interface FastEthernet0/4
switchport trunk native vlan 33
switchport trunk allowed vlan 33,35
switchport mode trunk
interface Vlan33
ip address 172.17.33.1 255.255.255.0
ip helper-address 172.17.4.1
interface Vlan35
ip address 172.17.35.1 255.255.255.0
Logging display requested on 2024/03/04 14:22:35 (AST) for Hostname: [WLC], Model: [C9800-CL-K9], Version: [17.09.04a], SN: [9T55JTSG6NS], MD_SN: [9T55JTSG6NS]
2024/03/04 14:18:37.987144415 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Association received. BSSID 1c6a.7a0f.c9df, WLAN flex98, Slot 1 AP 1c6a.7a0f.c9d0, AP1c6a.7a16.df48
2024/03/04 14:18:37.987621793 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2024/03/04 14:18:37.988899509 {wncd_x_R0-0}{1}: [dot11] [19713]: (note): MAC: 6a4d.625d.b5bc Association success. AID 1, Roaming = False, WGB = False, 11r = False, 11w = False Fast roam = False
2024/03/04 14:18:37.989266986 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2024/03/04 14:18:37.989325105 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc L2 Authentication initiated. method PSK, Policy VLAN 35, AAA override = 0, NAC = 0
2024/03/04 14:18:37.993135827 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [19713]: (note): Authentication Success. Resolved Policy bitmap:11 for client 6a4d.625d.b5bc
2024/03/04 14:18:37.993550409 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x1 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:18:38.030644186 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (note): MAC: 6a4d.625d.b5bc EAP Key management successful. AKM:PSK Cipher:CCMP WPA Version: WPA2
2024/03/04 14:18:38.030829181 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc L2 PSK Authentication Success. EAP type: NA, Resolved VLAN: 35, Audit Session id: 320A16AC00006AD10AB0643D
2024/03/04 14:18:38.032379662 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility discovery triggered. Client mode: Flex - Local Switching
2024/03/04 14:18:38.032390232 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2024/03/04 14:18:38.036800159 {wncd_x_R0-0}{1}: [mm-client] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa0000028, Client Role: Local PoA: 0x90000010 PoP: 0x0
2024/03/04 14:18:38.037628927 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x2 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:18:38.037753909 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2024/03/04 14:18:38.038127288 {wncd_x_R0-0}{1}: [dot11] [19713]: (note): MAC: 6a4d.625d.b5bc Client datapath entry params - ssid:flex98,slot_id:1 bssid ifid: 0x0, radio_ifid: 0x9000000e, wlan_ifid: 0xf0400005
2024/03/04 14:18:38.039452880 {wncd_x_R0-0}{1}: [dpath_svc] [19713]: (note): MAC: 6a4d.625d.b5bc Client datapath entry created for ifid 0xa0000028
2024/03/04 14:18:38.041591316 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2024/03/04 14:20:37.942566063 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_MN_DHCP_TIMEOUT, details: , fsm-state transition 00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|01|07|15|1a|1b|2c|37|46|48|4a|4c|a5|
2024/03/04 14:20:37.942919269 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Delete mobile payload sent for BSSID: 1c6a.7a0f.c9df WTP mac: 1c6a.7a0f.c9d0 slot id: 1
2024/03/04 14:20:37.942941682 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_DELETE_IN_PROGRESS
2024/03/04 14:20:37.944991266 {wncd_x_R0-0}{1}: [dpath_svc] [19713]: (note): MAC: 6a4d.625d.b5bc Client datapath entry deleted for ifid 0xa0000028
2024/03/04 14:20:37.945448020 {wncd_x_R0-0}{1}: [sanet-shim-translate] [19713]: (note): MAC: 6a4d.625d.b5bc Session manager disconnect event called, session label: 0x80000a39
2024/03/04 14:20:37.947476416 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_DELETE_IN_PROGRESS -> S_CO_DELETED
2024/03/04 14:20:38.310131600 {wncd_x_R0-0}{1}: [dot11] [19713]: (ERR): MAC: 6a4d.625d.b5bc DOT11 fsm is not allocated yet.
2024/03/04 14:20:48.473437487 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (ERR): MAC: 0000.0000.0000 vlan_mode_api: fsm_ctxt not found
2024/03/04 14:21:45.549279243 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): Failed to dot11 get vendor specific id. Wrong vendor ie Type(1) received
2024/03/04 14:21:45.549855848 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Association received. BSSID 1c6a.7a0f.c9df, WLAN flex98, Slot 1 AP 1c6a.7a0f.c9d0, AP1c6a.7a16.df48
2024/03/04 14:21:45.550004574 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Received Dot11 association request. Processing started,SSID: flex98, Policy profile: sucursal1_WLANID_5, AP Name: AP1c6a.7a16.df48, Ap Mac Address: 1c6a.7a0f.c9d0BSSID MAC0000.0000.0000wlan ID: 5RSSI: -32, SNR: 62
2024/03/04 14:21:45.550419838 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2024/03/04 14:21:45.550952618 {wncd_x_R0-0}{1}: [dot11-validate] [19713]: (info): MAC: 6a4d.625d.b5bc Dot11 ie validate ext/supp rates. Validation Passed for Supported rates radio_type 2
2024/03/04 14:21:45.550957610 {wncd_x_R0-0}{1}: [dot11-validate] [19713]: (info): MAC: 6a4d.625d.b5bc WiFi direct: Dot11 validate P2P IE. P2P IE not present.
2024/03/04 14:21:45.551327871 {wncd_x_R0-0}{1}: [dot11] [19713]: (debug): MAC: 6a4d.625d.b5bc dot11 send association response. Framing association response with resp_status_code: 0
2024/03/04 14:21:45.551329050 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc Dot11 capability privacy bit set TRUE
2024/03/04 14:21:45.551338096 {wncd_x_R0-0}{1}: [dot11] [19713]: (debug): MAC: 6a4d.625d.b5bc Dot11 Capability info byte1 11, byte2: 11
2024/03/04 14:21:45.551460495 {wncd_x_R0-0}{1}: [dot11-frame] [19713]: (info): MAC: 6a4d.625d.b5bc WiFi direct: skip build Assoc Resp with P2P IE: Wifi direct policy disabled
2024/03/04 14:21:45.551829428 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc dot11 send association response. Sending assoc response of length: 137 with resp_status_code: 0, DOT11_STATUS: DOT11_STATUS_SUCCESS
2024/03/04 14:21:45.551897916 {wncd_x_R0-0}{1}: [dot11] [19713]: (note): MAC: 6a4d.625d.b5bc Association success. AID 1, Roaming = False, WGB = False, 11r = False, 11w = False Fast roam = False
2024/03/04 14:21:45.551948261 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc DOT11 state transition: S_DOT11_INIT -> S_DOT11_ASSOCIATED
2024/03/04 14:21:45.552088318 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Station Dot11 association is successful.
2024/03/04 14:21:45.552247105 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Starting L2 authentication. Bssid in state machine:1c6a.7a0f.c9df Bssid in request is:1c6a.7a0f.c9df
2024/03/04 14:21:45.552312113 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2024/03/04 14:21:45.552384397 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc L2 Authentication initiated. method PSK, Policy VLAN 35, AAA override = 0, NAC = 0
2024/03/04 14:21:45.552796901 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Session Start event called from SANET-SHIM, vlan: 0
2024/03/04 14:21:45.552885645 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Wireless session sequence, create context with method No method
2024/03/04 14:21:45.552914578 {wncd_x_R0-0}{1}: [auth-mgr-feat_wireless] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] - authc_list: Not present under wlan configuration
2024/03/04 14:21:45.552916551 {wncd_x_R0-0}{1}: [auth-mgr-feat_wireless] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] - authz_list: Not present under wlan configuration
2024/03/04 14:21:45.553061616 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_INIT -> S_AUTHIF_AWAIT_PSK_AUTH_START_RESP
2024/03/04 14:21:45.553454571 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:unknown] auth mgr attr add/change notification is received for attr iif-id(952)
2024/03/04 14:21:45.553597095 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr swbidb(1263)
2024/03/04 14:21:45.553679458 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr aaa-unique-id(220)
2024/03/04 14:21:45.553738842 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr iif-id(952)
2024/03/04 14:21:45.553764521 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Retrieved Client IIF ID 0x4e0004bc
2024/03/04 14:21:45.553883900 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr audit-session-id(819)
2024/03/04 14:21:45.553908678 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Allocated audit session id 320A16AC00006ADA0AB340E9
2024/03/04 14:21:45.554618704 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Applying policy for WlanId: 5, bssid : 1c6a.7a0f.c9df, slotid: 1 bssid hdl : 12364632848013991690
2024/03/04 14:21:45.554626858 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Wlan vlan-id from bssid hdl 35
2024/03/04 14:21:45.554691914 {wncd_x_R0-0}{1}: [svm] [19713]: (info): SVM_INFO: Applying Svc Templ wlan_svc_sucursal1_WLANID_5 (ML:NONE)
2024/03/04 14:21:45.580683696 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr vlan-id(965)
2024/03/04 14:21:45.580752268 {wncd_x_R0-0}{1}: [epm] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Vlan tag name is 35, pref is 1048575 vlan num is 35
2024/03/04 14:21:45.580864201 {wncd_x_R0-0}{1}: [epm] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Feature (EPM Vlan PLUG-IN) has been started (status Success)
2024/03/04 14:21:45.580897288 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] SM Reauth Plugin: Received valid timeout = 1800, effective timeout = 1800
2024/03/04 14:21:45.580978377 {wncd_x_R0-0}{1}: [epm] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Feature (SM Reauth PLUG-IN) has been started (status Success)
2024/03/04 14:21:45.581372351 {wncd_x_R0-0}{1}: [svm] [19713]: (info): SVM_INFO: Response of epm is SYNC with return code Success
2024/03/04 14:21:45.581530122 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Raising ext evt Template Activated (9) on this session, client (unknown) (0)
2024/03/04 14:21:45.581752910 {wncd_x_R0-0}{1}: [llbridge-main] [19713]: (debug): MAC: 6a4d.625d.b5bc Link-local bridging not enabled for this client, not checking VLAN validity
2024/03/04 14:21:45.581939170 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr auth-domain(954)
2024/03/04 14:21:45.582070229 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Raised event AUTHZ_SUCCESS (11)
2024/03/04 14:21:45.582081565 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Context changing state from 'Idle' to 'Authz Success'
2024/03/04 14:21:45.582093266 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Authorized open auth session for 6a4d.625d.b5bc
2024/03/04 14:21:45.582138619 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] SM will not send event Template Activated to PRE for 0xCF000ACC
2024/03/04 14:21:45.582405750 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_AWAIT_PSK_AUTH_START_RESP -> S_AUTHIF_PSK_AUTH_PENDING
2024/03/04 14:21:45.582416336 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [19713]: (note): Authentication Success. Resolved Policy bitmap:11 for client 6a4d.625d.b5bc
2024/03/04 14:21:45.582559595 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Client QoS add mobile cb
2024/03/04 14:21:45.582782310 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:0. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:21:45.582796755 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:1. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:21:45.582917116 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x1 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:21:45.582945653 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_PENDING -> S_AUTHIF_ADD_MOBILE_ACK_WAIT_KM
2024/03/04 14:21:45.590600385 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_ADD_MOBILE_ACK_WAIT_KM -> S_AUTHIF_PSK_AUTH_KEY_XCHNG_PENDING
2024/03/04 14:21:45.591018442 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc EAP key M1 Sent successfully
2024/03/04 14:21:45.591023854 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_INITPMK -> S_PTK_START
2024/03/04 14:21:45.627830710 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc M2 Status: EAP key M2 validation success
2024/03/04 14:21:45.628715301 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc EAP key M3 Sent successfully
2024/03/04 14:21:45.628719266 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_PTK_START -> S_PTKINITNEGOTIATING
2024/03/04 14:21:45.634125368 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc M4 Status: EAP key M4 validation is successful
2024/03/04 14:21:45.634282615 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (note): MAC: 6a4d.625d.b5bc EAP Key management successful. AKM:PSK Cipher:CCMP WPA Version: WPA2
2024/03/04 14:21:45.634324916 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_PTKINITNEGOTIATING -> S_PTKINITDONE
2024/03/04 14:21:45.634562043 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc L2 PSK Authentication Success. EAP type: NA, Resolved VLAN: 35, Audit Session id: 320A16AC00006ADA0AB340E9
2024/03/04 14:21:45.634624472 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_KEY_XCHNG_PENDING -> S_AUTHIF_PSK_AUTH_DONE
2024/03/04 14:21:45.634688547 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc L2 Authentication of station is successful., L3 Authentication : 0
2024/03/04 14:21:45.634817138 {wncd_x_R0-0}{1}: [dot1x] [19713]: (info): [0000.0000.0000:capwap_90000010] Couldn't find the supplicant in the list
2024/03/04 14:21:45.637925090 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility discovery triggered. Client mode: Flex - Local Switching
2024/03/04 14:21:45.637934705 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2024/03/04 14:21:45.637982912 {wncd_x_R0-0}{1}: [mm-transition] [19713]: (info): MAC: 6a4d.625d.b5bc MMIF FSM transition: S_MA_INIT -> S_MA_MOBILITY_DISCOVERY_PROCESSED_TR on E_MA_MOBILITY_DISCOVERY
2024/03/04 14:21:45.638232474 {wncd_x_R0-0}{1}: [mm-client] [19713]: (info): MAC: 6a4d.625d.b5bc Invalid transmitter ip in build client context
2024/03/04 14:21:45.638560588 {wncd_x_R0-0}{1}: [mm-client] [19713]: (debug): MAC: 6a4d.625d.b5bc Sending mobile_announce of XID (0) to (MobilityD[0])
2024/03/04 14:21:45.638875278 {mobilityd_R0-0}{1}: [mm-client] [21565]: (debug): MAC: 6a4d.625d.b5bc Received mobile_announce, sub type: 0 of XID (0) from (WNCD[0])
2024/03/04 14:21:45.639488646 {mobilityd_R0-0}{1}: [mm-transition] [21565]: (info): MAC: 6a4d.625d.b5bc MMFSM transition: S_MC_INIT -> S_MC_ANNOUNCE_PROCESSED_NEW_CLIENT_TR on E_MC_ANNOUNCE_RCVD from WNCD[0]
2024/03/04 14:21:45.639680128 {mobilityd_R0-0}{1}: [mm-client] [21565]: (debug): MAC: 6a4d.625d.b5bc Add MCC by tdl mac: client_ifid 0xa0000028 is assigned to client
2024/03/04 14:21:45.639738198 {mobilityd_R0-0}{1}: [mm-client] [21565]: (debug): MAC: 6a4d.625d.b5bc Sending capwap_msg_unknown (100) of XID (69874) to (WNCD[0])
2024/03/04 14:21:45.639841799 {mobilityd_R0-0}{1}: [mm-client] [21565]: (debug): MAC: 0000.0000.0000 Sending mobile_announce_nak of XID (69874) to (WNCD[0])
2024/03/04 14:21:45.642680882 {wncd_x_R0-0}{1}: [mm-client] [19713]: (debug): MAC: 6a4d.625d.b5bc Received mobile_announce_nak, sub type: 1 of XID (69874) from (MobilityD[0])
2024/03/04 14:21:45.642857469 {wncd_x_R0-0}{1}: [mm-transition] [19713]: (info): MAC: 6a4d.625d.b5bc MMIF FSM transition: S_MA_INIT_WAIT_ANNOUNCE_RSP -> S_MA_NAK_PROCESSED_TR on E_MA_NAK_RCVD
2024/03/04 14:21:45.642903012 {wncd_x_R0-0}{1}: [mm-client] [19713]: (info): MAC: 6a4d.625d.b5bc Roam type changed - None -> None
2024/03/04 14:21:45.642945252 {wncd_x_R0-0}{1}: [mm-client] [19713]: (info): MAC: 6a4d.625d.b5bc Mobility role changed - Unassoc -> Local
2024/03/04 14:21:45.643151596 {wncd_x_R0-0}{1}: [mm-client] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa0000028, Client Role: Local PoA: 0x90000010 PoP: 0x0
2024/03/04 14:21:45.643269132 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Processing mobility response from MMIF. Client ifid: 0xa0000028, roam type: None, client role: Local
2024/03/04 14:21:45.643774677 {wncd_x_R0-0}{1}: [dot1x] [19713]: (info): [0000.0000.0000:capwap_90000010] Couldn't find the supplicant in the list
2024/03/04 14:21:45.643888896 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Client QoS add mobile cb
2024/03/04 14:21:45.644042732 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:0. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:21:45.644074050 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:1. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:21:45.644214912 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Build AAA QoS Params for addMobile: aaa_avgdtus:0, aaa_avgrtdtus:0, aaa_bstdtus:0, aaa_bstrtdtus:0, aaa_avgdtds:0, aaa_avgrtdtds:0, aaa_bstdtds:0, aaa_bstrtdtds:0, aaa_sig:1431655765
2024/03/04 14:21:45.644219995 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Qos rate-limit parameters encoded successfully in addMobile payload from qos addMobile callback
2024/03/04 14:21:45.644309296 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x2 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:21:45.644487260 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2024/03/04 14:21:45.644947255 {wncd_x_R0-0}{1}: [dot11] [19713]: (note): MAC: 6a4d.625d.b5bc Client datapath entry params - ssid:flex98,slot_id:1 bssid ifid: 0x0, radio_ifid: 0x9000000e, wlan_ifid: 0xf0400005
2024/03/04 14:21:45.645006105 {wncd_x_R0-0}{1}: [llbridge-main] [19713]: (debug): MAC: 6a4d.625d.b5bc Link-local bridging not enabled for this client, not checking VLAN validity
2024/03/04 14:21:45.645047915 {wncd_x_R0-0}{1}: [llbridge-main] [19713]: (debug): MAC: 6a4d.625d.b5bc Link Local Bridging not enabled for client
2024/03/04 14:21:45.645049466 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Client QoS dpath create params
2024/03/04 14:21:45.645109951 {wncd_x_R0-0}{1}: [avc-afc] [19713]: (debug): AVC enabled for client 6a4d.625d.b5bc
2024/03/04 14:21:45.645772476 {wncd_x_R0-0}{1}: [dpath_svc] [19713]: (note): MAC: 6a4d.625d.b5bc Client datapath entry created for ifid 0xa0000028
2024/03/04 14:21:45.646479960 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2024/03/04 14:21:45.668308292 {wncd_x_R0-0}{1}: [client-iplearn] [19713]: (info): MAC: 6a4d.625d.b5bc IP-learn state transition: S_IPLEARN_INIT -> S_IPLEARN_IN_PROGRESS
2024/03/04 14:21:45.670020476 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_DONE -> S_AUTHIF_PSK_AUTH_DONE
2024/03/04 14:21:45.748678606 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:21:45.749324642 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:21:46.683722224 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:21:46.684063355 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:21:47.615388451 {wncd_x_R0-0}{1}: [client-iplearn] [19713]: (info): MAC: 6a4d.625d.b5bc Client IP learn successful. Method: IPv6 Snooping IP: fe80::684d:62ff:fe5d:b5bc
2024/03/04 14:21:47.616114791 {wncd_x_R0-0}{1}: [auth-mgr] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] auth mgr attr add/change notification is received for attr addrv6(10)
2024/03/04 14:21:47.616255302 {wncd_x_R0-0}{1}: [auth-mgr-feat_acct] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] SM Notified attribute Add/Update ipv6_addr fe80::684d:62ff:fe5d:b5bc
2024/03/04 14:21:47.616358720 {wncd_x_R0-0}{1}: [client-iplearn] [19713]: (info): MAC: 6a4d.625d.b5bc IP-learn state transition: S_IPLEARN_IN_PROGRESS -> S_IPLEARN_IN_PROGRESS
2024/03/04 14:21:48.723910831 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:21:48.724326983 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:21:52.370698126 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:21:52.370921730 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:01.041595506 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:01.042003826 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:06.773973027 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): Failed to dot11 get vendor specific id. Wrong vendor ie Type(1) received
2024/03/04 14:22:06.774006141 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Association received. BSSID 1c6a.7a0f.c9df, WLAN flex98, Slot 1 AP 1c6a.7a0f.c9d0, AP1c6a.7a16.df48, old BSSID 1c6a.7a0f.c9df
2024/03/04 14:22:06.774229491 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Received Dot11 association request. Processing started,SSID: flex98, Policy profile: sucursal1_WLANID_5, AP Name: AP1c6a.7a16.df48, Ap Mac Address: 1c6a.7a0f.c9d0BSSID MAC1c6a.7a0f.c9dfwlan ID: 5RSSI: -33, SNR: 63
2024/03/04 14:22:06.774345552 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2024/03/04 14:22:06.774655481 {wncd_x_R0-0}{1}: [dot11-validate] [19713]: (info): MAC: 6a4d.625d.b5bc Dot11 ie validate ext/supp rates. Validation Passed for Supported rates radio_type 2
2024/03/04 14:22:06.774661523 {wncd_x_R0-0}{1}: [dot11-validate] [19713]: (info): MAC: 6a4d.625d.b5bc WiFi direct: Dot11 validate P2P IE. P2P IE not present.
2024/03/04 14:22:06.774920173 {wncd_x_R0-0}{1}: [dot11] [19713]: (debug): MAC: 6a4d.625d.b5bc dot11 send association response. Framing association response with resp_status_code: 0
2024/03/04 14:22:06.774921791 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc Dot11 capability privacy bit set TRUE
2024/03/04 14:22:06.774931438 {wncd_x_R0-0}{1}: [dot11] [19713]: (debug): MAC: 6a4d.625d.b5bc Dot11 Capability info byte1 11, byte2: 11
2024/03/04 14:22:06.775012704 {wncd_x_R0-0}{1}: [dot11-frame] [19713]: (info): MAC: 6a4d.625d.b5bc WiFi direct: skip build Assoc Resp with P2P IE: Wifi direct policy disabled
2024/03/04 14:22:06.775314417 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc dot11 send association response. Sending assoc response of length: 137 with resp_status_code: 0, DOT11_STATUS: DOT11_STATUS_SUCCESS
2024/03/04 14:22:06.775331184 {wncd_x_R0-0}{1}: [dot11] [19713]: (note): MAC: 6a4d.625d.b5bc Association success. AID 1, Roaming = False, WGB = False, 11r = False, 11w = False Fast roam = False
2024/03/04 14:22:06.775370938 {wncd_x_R0-0}{1}: [dot11] [19713]: (info): MAC: 6a4d.625d.b5bc DOT11 state transition: S_DOT11_ASSOCIATED -> S_DOT11_ASSOCIATED
2024/03/04 14:22:06.775598529 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Station Dot11 association is successful.
2024/03/04 14:22:06.775688199 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Starting L2 authentication. Bssid in state machine:1c6a.7a0f.c9df Bssid in request is:1c6a.7a0f.c9df
2024/03/04 14:22:06.775769310 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_L2_AUTH_IN_PROGRESS
2024/03/04 14:22:06.776018032 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Client QoS add mobile cb
2024/03/04 14:22:06.776151283 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:0. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:22:06.776215894 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:1. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:22:06.776346472 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Build AAA QoS Params for addMobile: aaa_avgdtus:0, aaa_avgrtdtus:0, aaa_bstdtus:0, aaa_bstrtdtus:0, aaa_avgdtds:0, aaa_avgrtdtds:0, aaa_bstdtds:0, aaa_bstrtdtds:0, aaa_sig:1431655765
2024/03/04 14:22:06.776351048 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Qos rate-limit parameters encoded successfully in addMobile payload from qos addMobile callback
2024/03/04 14:22:06.776464911 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x1 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:22:06.776493119 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_DONE -> S_AUTHIF_ADD_MOBILE_ACK_WAIT_KM
2024/03/04 14:22:06.780313900 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_ADD_MOBILE_ACK_WAIT_KM -> S_AUTHIF_PSK_AUTH_KEY_XCHNG_PENDING
2024/03/04 14:22:06.780623147 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc EAP key M1 Sent successfully
2024/03/04 14:22:06.780628861 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_PTKINITDONE -> S_PTK_START
2024/03/04 14:22:06.804963380 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc M2 Status: EAP key M2 validation success
2024/03/04 14:22:06.805327960 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc EAP key M3 Sent successfully
2024/03/04 14:22:06.805332694 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_PTK_START -> S_PTKINITNEGOTIATING
2024/03/04 14:22:06.812049851 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc M4 Status: EAP key M4 validation is successful
2024/03/04 14:22:06.812057793 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (note): MAC: 6a4d.625d.b5bc EAP Key management successful. AKM:PSK Cipher:CCMP WPA Version: WPA2
2024/03/04 14:22:06.812108620 {wncd_x_R0-0}{1}: [client-keymgmt] [19713]: (info): MAC: 6a4d.625d.b5bc Client key-mgmt state transition: S_PTKINITNEGOTIATING -> S_PTKINITDONE
2024/03/04 14:22:06.812505555 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc L2 PSK Authentication Success. EAP type: NA, Resolved VLAN: 35, Audit Session id: 320A16AC00006ADA0AB340E9
2024/03/04 14:22:06.812604456 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_KEY_XCHNG_PENDING -> S_AUTHIF_PSK_AUTH_DONE
2024/03/04 14:22:06.812697120 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc L2 Authentication of station is successful., L3 Authentication : 0
2024/03/04 14:22:06.812949753 {wncd_x_R0-0}{1}: [dot1x] [19713]: (info): [0000.0000.0000:capwap_90000010] Couldn't find the supplicant in the list
2024/03/04 14:22:06.813974086 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility discovery triggered. Client mode: Flex - Local Switching
2024/03/04 14:22:06.813987455 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2024/03/04 14:22:06.814049081 {wncd_x_R0-0}{1}: [mm-transition] [19713]: (info): MAC: 6a4d.625d.b5bc MMIF FSM transition: S_MA_LOCAL -> S_MA_LOCAL on E_MA_MOBILITY_DISCOVERY
2024/03/04 14:22:06.814050849 {wncd_x_R0-0}{1}: [mm-client] [19713]: (debug): MAC: 6a4d.625d.b5bc Mobility Role is known. Responding to CO with mobility complete
2024/03/04 14:22:06.814052277 {wncd_x_R0-0}{1}: [mm-client] [19713]: (info): MAC: 6a4d.625d.b5bc Mobility role changed - Local -> Local
2024/03/04 14:22:06.814053682 {wncd_x_R0-0}{1}: [mm-client] [19713]: (info): MAC: 6a4d.625d.b5bc Sub Roam type changed - MM_SUB_ROAM_TYPE_NONE -> MM_SUB_ROAM_TYPE_INTRA_INSTANCE
2024/03/04 14:22:06.814158760 {wncd_x_R0-0}{1}: [mm-client] [19713]: (note): MAC: 6a4d.625d.b5bc Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_INTRA_INSTANCE, Client IFID: 0xa0000028, Client Role: Local PoA: 0x90000010 PoP: 0x0
2024/03/04 14:22:06.814261920 {wncd_x_R0-0}{1}: [client-orch-sm] [19713]: (debug): MAC: 6a4d.625d.b5bc Processing mobility response from MMIF. Client ifid: 0xa0000028, roam type: None, client role: Local
2024/03/04 14:22:06.814748808 {wncd_x_R0-0}{1}: [dot1x] [19713]: (info): [0000.0000.0000:capwap_90000010] Couldn't find the supplicant in the list
2024/03/04 14:22:06.814904478 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Client QoS add mobile cb
2024/03/04 14:22:06.815058125 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:0. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:22:06.815089256 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc No QoS PM Name or QoS Level received from SANet for pm_dir:1. Check client is fastlane, otherwise set pm name to none
2024/03/04 14:22:06.815247939 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Build AAA QoS Params for addMobile: aaa_avgdtus:0, aaa_avgrtdtus:0, aaa_bstdtus:0, aaa_bstrtdtus:0, aaa_avgdtds:0, aaa_avgrtdtds:0, aaa_bstdtds:0, aaa_bstrtdtds:0, aaa_sig:1431655765
2024/03/04 14:22:06.815252858 {wncd_x_R0-0}{1}: [ewlc-qos-client] [19713]: (info): MAC: 6a4d.625d.b5bc Qos rate-limit parameters encoded successfully in addMobile payload from qos addMobile callback
2024/03/04 14:22:06.815339136 {wncd_x_R0-0}{1}: [client-auth] [19713]: (note): MAC: 6a4d.625d.b5bc ADD MOBILE sent. Client state flags: 0x2 BSSID: MAC: 1c6a.7a0f.c9df capwap IFID: 0x90000010, Add mobiles sent: 1
2024/03/04 14:22:06.815476385 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2024/03/04 14:22:06.816211562 {wncd_x_R0-0}{1}: [client-orch-state] [19713]: (note): MAC: 6a4d.625d.b5bc Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2024/03/04 14:22:06.816356624 {wncd_x_R0-0}{1}: [client-iplearn] [19713]: (info): MAC: 6a4d.625d.b5bc IP-learn state transition: S_IPLEARN_IN_PROGRESS -> S_IPLEARN_IN_PROGRESS
2024/03/04 14:22:06.819980543 {wncd_x_R0-0}{1}: [client-auth] [19713]: (info): MAC: 6a4d.625d.b5bc Client auth-interface state transition: S_AUTHIF_PSK_AUTH_DONE -> S_AUTHIF_PSK_AUTH_DONE
2024/03/04 14:22:06.962921916 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:06.963328831 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:07.989990533 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:07.990605191 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:10.044149735 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:10.044565633 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:14.239800483 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:14.240238853 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
2024/03/04 14:22:21.636052115 {wncd_x_R0-0}{1}: [auth-mgr-feat_dsensor] [19713]: (info): [6a4d.625d.b5bc:capwap_90000010] Skipping DHCP TLVs for further processing. DHCP based classification isn't enabled
2024/03/04 14:22:21.636504500 {wncd_x_R0-0}{1}: [sisf-packet] [19713]: (info): RX: DHCPv4 from interface capwap_90000010 on vlan 35 Src MAC: 6a4d.625d.b5bc Dst MAC: ffff.ffff.ffff src_ip: 0.0.0.0, dst_ip: 255.255.255.255, BOOTPREQUEST, SISF_DHCPDISCOVER, giaddr: 0.0.0.0, yiaddr: 0.0.0.0, CMAC: 6a4d.625d.b5bc
From Cisco Debug Analyzer, the client "6a4d.625d.b5bc" sent multiple DHCP discover messages, but never got response.
"Sending DHCP Discover to: 255.255.255.255 on vlan 35 through gateway 0.0.0.0"
Make sure DHCP server reachability on VLAN 33 & 35. Also verify DHCP logs for the client request.
Jagan Chowdam
What is your Policy Tag and Site Tag configuration look like? Have you unchecked "Enable Local Site" under  Site Tag and selected appropriate Flex Profile?
You can use the following Cisco ref link or Rasika's blog post and cross check your configuration
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213945-understand-flexconnect-on-9800-wireless.html
https://mrncciew.com/2023/01/21/9800-flexconnect-basics/
Jagan Chowdam
/**Pls rate useful responses**/
Jagan Chowdam
Leo TI
I inform you that the problem was a missing route
,thank you so much
