WLC 9800 with DNA-Center restrictions AP's on Remote locations
p.willemsen
When I using DNA-Center with WLC-9800L what are the restrictions on remote locations Access point.
We are using FlexConnect for the AP's.
Question is: When your need a local Wireless Lan Controller on Remote Location, example when you have more then 25 AP's.
Or there is a depend how the AP are used ??
Best Regards,
Piet.
balaji.bandi
Is the remote part of Fabric or SD-WAN
OTT is the solution for now for the branches or branch can have Fabric in Box.
BB
I have still the question can I use the WLC appliance in a fabric of  DNA Central
When you can use that what is the effect on your Remote locations for the AP's.
In the past was a rule when you have 25 AP's you must use Local WLC Controller.
Best Regards,
Piet
