WLC and AP Interfaces statistics
cnrs-dsi
Hello
I want to clear ethernet interfaces statistics from APs.
ALL AP/ Detail for AP XXX / interfaces / interface detail.
I can't found how to do that.
I have tried claer ap, clear stats ...no result
Thanks for help
I never knew that you were using the LWAPP APs if so, we need to login to the AP and issue the same command..
That is..
AP#debul capwap console cli  (This hidden command will help you out in getting into the config mode on the LWAPP AP)
OR
AP#debul lwapp console cli (This hidden command will help you out in getting into the config mode on the LWAPP AP)
AP#config t
Ap(conf t)#default interface fa 0
this may help you..
Or from the WLC.. here is the command..
WLC>config ap telnet enable
wlc> debug ap command "default interface fa 0"
This may help you!!
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Surendra BG
Default the interface and this will do it..
The command is ..
en
conf t# default interface fa 0
end
Surendra
Surendra BG
Hello Surendra
I am on a WLC 4002 and my AP are ligthweight AP.
I have no "conf t" possibility
I want to clear results of :
(Cisco Controller) >show ap stats ethernet summary
AP                   Interface Name    Status  Speed  Rx Packets  Tx Packets  Discards
ap1                   GigabitEthernet0   UP     100    2353053     860421      0
apt2                  GigabitEthernet0   UP     1000   3982738     2062225     0
That is..
OR
AP#config t
this may help you..
This may help you!!
Surendra
Surendra BG
It's ok.
thanks for your help.
I enable telnet on the ap and make a clear counters.
