WLC And Lobby Ambassador
b-ulrich1
Upgraded WLC 2504 from 7.6.120 to 7.6.130 and now I cannot log into the lobby ambassador portal.  I use the same user id and password, then it  says page cannot be displayed.  I created another lobby ambassador account and I am getting the same thing.  Any ideas?
Saurav Lodh
Level 7
Level 7
It is not an error with login credentials, but the web sever, I will suggest you to save the config. and reboot the controller , wait for a moment . Login with admin, logout and try the lobby login.
Here is the fix on this post...It works with a specific URL format...
https://supportforums.cisco.com/discussion/12302816/url-fail-when-access-lobby-admin
Hi b-ulrich1
I had the same issue this morning, the bad news for you, that is the bug CSCuq61753,
https://tools.cisco.com/quickview/bug/CSCuq61753
The good thing for you to know, you can solve it with this version 8.0.110.0
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr1.html
Have fun and keep posting
regards,
Alberto Badilla.
