WLC Certificate Issue
joeharb
Level 10
Level 10
I tried update our expiring WLC certificate and now I can't access the gui period.  I can get to the system via ssh.  I didn't know if there was simple way to reset the certificate back to the expired on or default one while I investigate the new certificate.
WLC 9800 version 17.06.01
Joe
patoberli
What message do you get in the browser if you try to?
Have you tried rebooting the WLC?
ERR_SSL_PROTOCOL_ERROR is what is displayed in Edge.
I have not rebooted but can do that tonight after business hours.
Rasika Nayanajith
Make sure HTTPS uses the trustpoint you created
Administration > Management > HTTP/HTTPS/Netconf and choose the imported certificate from the Trust Points drop-down list.
Then you have to restart HTTPS service using CLI given below
9800(config)#no ip http secure-server
9800(config)#ip http secure-server
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213917-generate-csr-for-third-party-certificate.html#anc26
As a side note, if you plan to reload the WLC, better you upgrade to the 17.6.3 version which is the latest in the 17.6.x code train that you are running.
Rasika
*** Pls rate all useful responses ***
