WLC Client Load Balancing
AlexZmann
I am curious about the client load balancing feature for a Cisco WLC.  Basically, if Client Load Balancing is enabled on a WLAN, will clients in that particular WLAN be balanced based on the total client count on the AP or the client count on that AP in the specified WLAN?
Thanks in advance for your responses.
Sandeep Choudhary
Check this about Load balancing:
https://supportforums.cisco.com/document/81896/load-balancing-and-band-select-cisco-wireless-lan-controller
Using Aggressive load balancing the LAP can be configured to load balance clients among AP on a per WLAN basis.
http://www.cisco.com/image/gif/paws/113160/aggressive-load-balancing-clients-00.pdf
Dont forget to rate helpful posts
Sandeep Choudhary
