WLC client wireless connection unavailable
CCC3
WLC: 3504 (8.10.171.0)
AP: 9115AXI
security : PSK
Flexconnect
Wireless cannot be connected.
Debug Client Results
You can see the following.
Client deletion code: default reason code for all client deletion requests
Cause: Error while configuring PMIPv6 MAG/ Error while creating data plane rules for client/ Error while redirection URL exists and Radius NAC with mac filtering is set, pending for posture/ no dot1x control block found for client, internal error/ client did not respond to retries for SA queries (802.11w)/ Default for flex local authentication client/ No client ACL in AP
WLC/AP is sending a connection response to the client with status code 12 = Unknown or invalid SSID
Is there anyone who knows?
If necessary, the entire debug log can also be delivered.
Mark Elsen
 - As per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html   upgrade to 8.10.196.0 first and check again , especially and also because a modern 9115AXI is in use here!
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Show the full configuration of the WLAN:
config paging disable
show wlan <WLAN ID>
