Showing results forĀ
Search instead forĀ
Did you mean:Ā
WLC connectivity issue with ACI
I do have issues in WLC after moving from traditinal 6500 switch to ACI leaf .
issue 1) Getting packet drops while pinging the virtual ip address and no drops in the physical IP address .
Issue 2) The MAC address of the WLC is reported in EndPoint dampening and freezing
5 Replies 5
it is possible to deploy within ACI -https://www.youtube.com/watch?v=lLxG8hd2QQ8
*****Help out other by using the rating system and marking answered questions as "Answered"*****
we tried the same deployment . But the packets are getting into FREEZE .
DeviceInterfaceMAC addressIP address
ibmdia-loncwlc01 redundancy-management  70:81:05:cf:e4:86 172.21.96.13
ibmdia-loncwlc01 management 70:81:05:cf:e4:80 172.21.96.4
 show coop internal info repo ep dampening
EP bd vnid : 14745594
EP mac : 70:81:05:CF:E4:80
num of ipv4 addresses : 1
num of ipv6 addresses : 0
Damp penalty : 6736
Damp status : FREEZE
Total no of dampened EPs = 1
-ACI-SP01#
we have the same problem. DId you find any solution for it?
Kind regards,
Stefan
Arshad Safrulla
Are you talking about a scenario where WLC-Active is in one fabric and the WLC-standby is in another fabric where the two fabrics are connected via ND NSO?
Both the WLCs are in same pod but in two different leaf swicthes . Still we have the same issue .
