ap flex mode
bluesea2010
Level 7
Level 7
I don't have  L2 adjacency between core  because the connection between core is layer 3 .
Since there is no  L2 adjacency between core  , I have to create SVI'S only on one core .
So the other option  is to create svi's on wlc. As per cisco it is not recommended .
What if I choose ap's in flex mode
Rich R
You're going to have to explain your topology and what you're trying to achieve better.  A diagram might help.
More generally you can configure SVI on WLC but that creates various potential security issues.  In fact certain features require SVI.  You can always put APs in flex mode if you want to but it's not clear what you're hoping to achieve by doing that.  Maybe you mean so that you can use flex local switching but again that really depends on your topology and what your requirements are.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Hi @Rich R
Below is the topology. in all the sites  between core 1 and  core 2  there is no layer 2 adjacency .
So if I do a Layer 2 connection between core and wlc (trunk) and the svi's on core
eg:
core 1
ssid staff
10.0.2.1/24
ssid guest
10.0.3.1/24
and core 1 fail , I wont be able to reach the gateway
So My question is if I am using flex mode , can I create the ssid'd gateway in the edge switches
And can you please brief what are the security issues may face if the svi's are on wlc
