WLC Flex Connect
hs08
AP for branch office registered to the WLC in Main Office, and the AP using flex connect mode.
If we see in below picture, VLAN 250, 118, 124, 117, 131 is not exist in the Main Office, only VLAN management 303 exist in the main office.
With this condition why we cannot access to the WLC management from the branch LAN? The WLC management now only can be accessed from Main Office LAN.
Pinging the WLC management address is success from branch LAN
But from WLC is not able to ping to all VLAN listed in the interfaces, example ping from WLC to VLAN 250 gateway (10.100.50.1)
In the branch office there also have VLAN 200 where this VLAN is not listed in the WLC and pinging from WLC to this VLAN is succeed
Anyone know why?
7 Replies 7
Flex AP and from wifi client sure you can not ping wmi of wlc.
Flex VLAN is not config in WLC so wlc can not reply to ping.
But still from AP IP you can ping to wlc wmi. Wlc know AP IP that how AP join WLC.
MHM
So it's normal that we not able access to the WLC if accessing from Flex VLAN?
Sure Yes' and as you mention in your post these vlan is missing from WLC.
MHM
No other way to enable this?
ammahend
If these vlans only exist in remote location where flexconnect APs are then these vlan don’t even need to exist on wlc, you can just define your branch SSID to VLAN mapping under flex connect group and push to branch AP.
-hope this helps-
Rich R
Like @ammahend says the whole point of Flex local switching VLANs is that they only exist at the AP location not on the WLC.
If you want to connect between site local VLAN and central VLAN you need a router network to provide that routing between the networks which are totally separate.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
