WLC Guest WEB Authentification
a-weitzel
Community Member
I would like to configure on a WLC 2504 Internet-Access for Guests through a web authentication.
But I always find configuration instructions only describe the with the additional anchor WLC?
This works but also without anchor WLC, right?
Can anyone give a hint on where I find a manual for it (ideal for Release 7.4 or 7.5) to me.
Thank you
Alexander
Stephen Rodriguez
Yes it will work.
You just need to define the L3 security as webauth in the WLAN.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Erwin Salazar
Should be fairly straight forward in the configuration guide below:
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_01010100.html#ID1389
Anchors are only typically needed in a DMZ environment if you want to segregate your guest traffic from your internal network.
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
George Stefanick
It does indeed. When I use the foreign controller for guest access, I often will use a 5508 in port mode (non lag) and break out a port for guest.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
