Wlc interface up-down frequently
Enamul.haque
Frequent Visitor
Frequent Visitor
Hi everyone
I have been facing a problem in the last few days. my 2504 wlc interface up and down frequently and for this aps and clients got to disconnect. I have change the Switch port, Wlc port, and cable and the problem remains the same. Please check below for the log:
346 Tue Dec 8 12:06:50 2020 Link Up: Slot: 0 Port: 1 Admin Status: Enable Oper Status: Link Up
347 Tue Dec 8 12:06:48 2020 Link Down: Slot: 0 Port: 1 Admin Status: Enable Oper Status: Link Down
348 Tue Dec 8 12:06:46 2020 Link Up: Slot: 0 Port: 1 Admin Status: Enable Oper Status: Link Up
349 Tue Dec 8 12:06:44 2020 Link Down: Slot: 0 Port: 1 Admin Status: Enable Oper Status: Link Down
Please help to solve this.
9 Replies 9
Leo Laohoo
Only 1 port enabled?  What about the other ports?
Same problem with port number WLC num 2
What model is the switch?
Cisco  WS-C2960X-24PS-L
Post the complete output to the following command:
sh version
sh interface <PORT> controll
SW# show version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 12-Jul-17 13:06 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
NGD-HO-2960X-13F-SW uptime is 2 weeks, 4 days, 3 hours, 37 minutes
System restarted at 11:51:07 BDT Fri Nov 20 2020
System image file is "flash:/c2960x-universalk9-mz.152-2.E7/c2960x-universalk9-mz.152-2.E7.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision S0) with 524288K bytes of memory.
Processor board ID FCW2142B5K5
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:27:90:AA:87:80
Motherboard assembly number : 73-16694-06
Power supply part number : 341-0528-02
Motherboard serial number : FOC21412QX9
Power supply serial number : LIT21362ZSZ
Model revision number : S0
Motherboard revision number : C0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC214110BC
System serial number : FCW2142B5K5
Top Assembly Part Number : 68-100472-03
Top Assembly Revision Number : F0
Version ID : V05
CLEI Code Number : CMMLR00ARE
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
Configuration register is 0xF
SW#show interfaces gi1/0/13 controller
GigabitEthernet1/0/13 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0027.90aa.878d (bia 0027.90aa.878d)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 7/255, rxload 7/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:19, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 737
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 30610000 bits/sec, 6318 packets/sec
5 minute output rate 29668000 bits/sec, 5379 packets/sec
139336511 packets input, 88362999836 bytes, 0 no buffer
Received 1311101 broadcasts (1219001 multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 1219001 multicast, 0 pause input
111557826 packets output, 85927905744 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet1/0/13 Receive
30903950 Bytes 2466101912 Bytes
111150283 Unicast frames 138028923 Unicast frames
272659 Multicast frames 1219019 Multicast frames
137643 Broadcast frames 92102 Broadcast frames
0 Too old frames 1578951457 Unicast bytes
0 Deferred frames 370819087 Multicast bytes
0 MTU exceeded frames 7629209 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 12133074 Minimum size frames
0 8 collision frames 32013874 65 to 127 byte frames
0 9 collision frames 36405054 128 to 255 byte frames
0 10 collision frames 5130849 256 to 511 byte frames
0 11 collision frames 2920639 512 to 1023 byte frames
0 12 collision frames 49043562 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 1 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 1692993 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
5695 64 byte frames 0 Valid frames, too small
10018135 127 byte frames
42209328 255 byte frames 0 Too old frames
5663744 511 byte frames 0 Valid oversize frames
2929893 1023 byte frames 0 System FCS error frames
34929601 1518 byte frames 0 RxPortFifoFull drop frame
15804189 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
What firmware is the controller running on?
8.5.161.0
May I see the logs on the switch showing the downstream port to the WLC are going down/up?
