WLC Management
rshick
Community Member
Does anyone know how to enable management of the WLC from a network which is WLAN enabled?
By default this is not possible but I was told that there is a way to enable this on the controller.
sungy
Level 3
Level 3
Management -> Mgmt via Wireless -> check Enable Controller Management to be accessible from Wireless Clients.
hope this helps.
yong
sungy
Level 3
Level 3
hope this helps.
yong
rshick
Community Member
That was it. Thank you very much.
