WLC Rebooting issue
Shaqib Lallmamode
Community Member
I have a WLC 2504 loaded with firmware 8.5 and 14 APs connected to it.
The WLC randomly reboots daily at no specific intervals.
***IoStats Summary***
Linux 2.6.21_mvlcge500-octeon-mips64_octeon_v2_be (localhost) 04/05/22
avg-cpu: %user %nice %system %iowait %steal %idle
0.42 0.03 0.18 0.00 0.00 99.37
Device: tps MB_read/s MB_wrtn/s MB_read MB_wrtn
sda 0.01 0.00 0.00 8 23
***IoStats Detail***
Device: rrqm/s wrqm/s r/s w/s rMB/s wMB/s avgrq-sz avgqu-sz await svctm %util
sda 0.04 0.06 0.01 0.00 0.00 0.00 62.52 0.00 449.04 11.63 0.01
Shaqib
9 Replies 9
Leo Laohoo
Post the complete output to the command "sh coredump summary" and "sh sysinfo".
Shaqib Lallmamode
Community Member
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.121.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... WLC1
System Location.................................. Server Room First Floor
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.224.249.200
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 1 days 3 hrs 49 mins 1 secs
System Timezone Location......................... (GMT +4:00) Muscat, Abu Dhabi
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... AE - United Arab Emirates
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +32 C
External Temperature............................. +37 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 146
OUI Classification Failure Count................. 7098
Burned-in MAC Address............................ F8:A5:C5:84:54:A0
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show coredump summary
Core Dump upload is enabled
FTP Server IP.................................... 172.16.30.2
FTP Filename..................................... wlc2504.txt
FTP Username..................................... root
FTP Password.....................................
in the OP you mentioned running 8.5 code : but below output show different :  Do you have both the images in the device ?
BB
Here's the reason why the WLC keeps reboot -- Unstable power source.
Yes, sorry it is the same WLC.
Thanks, will try to change the power adaptor.
Wut?
That is not what I said.
Investigate the power outlet the power supply is drawing power from or put the power supply behind a UPS.
Shaqib Lallmamode
Community Member
The device is already behind a clean power UPS in our Server room.
There are already various device on the same DPU.
 - Configure a syslog server, to send logs too, follow  up on operational logs being reported during (still) normal times , sometimes indicators can be found as to why the device reboots in the end or after a while.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
A hardware fault could also show as "Power on reset" so you might find you need to replace the hardware.
Rarely even a software fault could show that.
You AireOS version is very old - consider upgrade depending on whether your APs are supported.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ctr-ap_support
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc10
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
