WLC Web Auth Redirect Not Working
sujith
Hi, In cisco 2504 we created a guest network and authentication is web Auth. But it is not working on chrome. All other browser its working . IN chrome its showing an error. Please see the attached screen short. Product details below. Software Version 8.1.102.0 Field Recovery Image Version 7.6.101.1
alois.heilmaier
Looks like a Problem with Chrome security.
I have done some searches...
Maybe it is due to HSTS.
If you connect to your wireless SSID you have to open your brower and open a URL.
So could you try to open an unencrypted URL ?
Have any solution with ssl.
May i know any solution for this issue because i'm having the same as well, if possible to create a self signed cert on WLC will solve this issue at android google chrome browser?
