WLC wrong DHCP assignement
ez9
Level 3
Level 3
I have a setup with a WLC 5508. The APs are in local mode and I am using a radius server to autoassign VLAN and to authenticate the users via 802.1x. I have created all vlan interfaces on WLC controller.
Some of the clients are complaining that they haven't Internet access sometimes. After investigation I found out that as they are connected to the correct VLAN, they are getting wrong IP address from DHCP server. The DHCP server is not on WLC and in the interafaces on WLC I configured the DHCP proxy mode as: disabled.
I ran some debugs for one "problematic" client and I am getting the following output:
The correct VLAN is the 33(192.168.1.0/24) but I can see offers from VLAN 20 (192.168.200.0/22).
Any thoughts on this?
Thank you.
*Dot1x_NW_MsgTask_5: Oct 02 05:52:10.071: 38:87:d5:ea:20:ae Accounting NAI-Realm: <username>, from Mscb username : <username>
*Dot1x_NW_MsgTask_5: Oct 02 05:52:10.071: 38:87:d5:ea:20:ae 192.168.1.213 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL ACL ID 255,URL ACL Action 0)
*Dot1x_NW_MsgTask_5: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae 192.168.1.213 RUN (20) No 11v BTM
*Dot1x_NW_MsgTask_5: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae 192.168.1.213 RUN (20) NO release MSCB
*Dot1x_NW_MsgTask_5: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae Successfully Plumbed PTK session Keysfor mobile 38:87:d5:ea:20:ae
*pemReceiveTask: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae 192.168.1.213 tokenID = 217
*pemReceiveTask: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae 192.168.1.213 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Oct 02 05:52:10.072: 38:87:d5:ea:20:ae Pushing IPv6: fe80:0000:0000:0000:6dcd:0a45:b960:868d , intfId:12 and MAC: 38:87:d5:ea:20:ae , Binding to Data Plane. SUCCESS !!
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP received op BOOTREQUEST (1) (len 320,vlan 67, port 1, encap 0xec03, xid 0x289627c1)
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP processing DHCP REQUEST (3)
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP xid: 0x289627c1 (680929217), secs: 0, flags: 8000
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP chaddr: 38:87:d5:ea:20:ae
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP requested ip: 192.168.1.213
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP Opt82 bridge mode insertion enabled, inserts opt82 if opt82 is enabled vlan=33, datalen =18, optlen=76
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP successfully bridged packet to DS
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP received op BOOTREQUEST (1) (len 320,vlan 20, port 1, encap 0xec00, xid 0x289627c1)
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP (encap type 0xec00) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Oct 02 05:52:10.078: 38:87:d5:ea:20:ae DHCP dropping looped REQUEST from DS (encap type 0xec00)
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP received op BOOTREPLY (2) (len 308,vlan 33, port 1, encap 0xec00, xid 0x289627c1)
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP processing DHCP ACK (5)
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP xid: 0x289627c1 (680929217), secs: 0, flags: 8000
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP chaddr: 38:87:d5:ea:20:ae
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP ciaddr: 0.0.0.0, yiaddr: 192.168.1.213
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP siaddr: 192.168.1.1, giaddr: 0.0.0.0
*DHCP Socket Task: Oct 02 05:52:10.081: 38:87:d5:ea:20:ae DHCP server id: 192.168.1.1 rcvd server id: 192.168.1.1
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP successfully bridged packet to STA
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP received op BOOTREPLY (2) (len 308,vlan 20, port 1, encap 0xec00, xid 0x289627c1)
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP processing DHCP NAK (6)
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP xid: 0x289627c1 (680929217), secs: 0, flags: 8000
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP chaddr: 38:87:d5:ea:20:ae
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP siaddr: 0.0.0.0, giaddr: 0.0.0.0
*DHCP Socket Task: Oct 02 05:52:10.082: 38:87:d5:ea:20:ae DHCP server id: 192.168.200.1 rcvd server id: 192.168.200.1
10 Replies 10
Mark Elsen
 - When processed by : https://cway.cisco.com/wireless-debug-analyzer/ , your debug comes down to (Show all flags checked) :
             Oct 02 05:52:10.078*DHCP Socket TaskReceived DHCP request from client
           Oct 02 05:52:10.081*DHCP Socket TaskReceived DHCP ACK from DHCP server
           Oct 02 05:52:10.082*DHCP Socket TaskReceived DHCP NAK from DHCP server
 - Check the DHCP server configuration.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
ez9
Level 3
Level 3
thanks for the answer,
I will take a look on DHCP server. But in debug output I can see entries like:
The client is on VLAN 33. Why the bootrequests showing other VLANs? (vlan 20 is the guest VLAN-different SSID-no autoassignment via radius, Vlan 67 is the AP Management VLAN).
 - Beside other replies , I would also advice to have a checkup of the 5508 controller configuration with : https://cway.cisco.com/tools/WirelessAnalyzer/
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Arshad Safrulla
Hows the AP connecting switchport and WLC connecting switchport is configured? Are you using any Native VLAN for the trunks?
ez9
Level 3
Level 3
The WLC is connected in trunk mode. The native VLAN is the default (1). There is no SVI for VLAN 1.
The APs are connected in trunk mode using the Management VLAN (67) as native.
I think this has something to do with your AAA server. Please check the policies and make sure that VLAN's are not sent as a part of Radius Accept message.
ez9
Level 3
Level 3
I don't know if this helping you somehow. I am attaching a screenshot from the policy that I configured on RADIUS server for VLAN assignement.
Rich R
Or you have a layer 2 loop somewhere such that DHCP request broadcasts are leaking onto other VLANs.
What version of software are you using?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
ez9
Level 3
Level 3
Thanks for your input,
The version is the 8.5.182.0 (I think this is the latest version for 5508). I upgraded to this version just yesterday. Before the WLC had the 8.5.171.0. I found out the the 8.5.182.0 resolving the bug CSCvx61201. I don't know if this fits 100% my setup but I give it a chance.
I checked all switches. I am running RPVST everywhere. I wll take a capture just in case.
Rich R
Yes that looks like a good possible match - hopefully that resolves your problem.
