WLC
athan1234
Level 8
Level 8
. I come to put it in the same vlan identificator, but my client tells me it does not work yet. Why ?
balaji.bandi
When you change the VLAN - on the Switch also you need to change the VLAN, also on switch worth clear ip arp related to that IP.
Quesitons to ask client, does they see SSID ? on the wifi device ?
or what is the defination of does not work ?
BB
balaji.bandi
BB
I am able to solved it . Thanks for your reply
