WLC2006 Temperature Sensor
tironevi
Does anyone know how I can see what the internal temperature of a WLC-2006. My WLC 2006 is running software version 4.2.130.0.
ET
With my 4400 and 2100 serie WLCs I can verify the internal temperature by either the web browser's monitor tab or by typing 'show sysinfo' within an SSL shell. This does not seem to work for my 2006 model.
perrychan
Community Member
I upgraded to v5.0.148.0 and now I can see the Internal Temperature on my WLC-2006's.
Yes... The 4.2 code doesn't have that anymore. I think the 4.1 or 4.0 code had that.
-Scott
Thank you for your responses. I will upgrade to version 5 as perrychan has done.
Didn't you find it funny that when there ws the error that the WLC showed 5000 degrees? Hotter than the surface of the sun! Nuclear in fact!
