WLC4136 Wirless Controller and Network Projectors
tom.mckim
Community Member
I have a WLC4136 wireless controller with AP1020 access points.
The wireless network runs fine.
I have recently purchased an NEC P350W projector.
It has network projecting capabilites.  I have the projector wired into our network as it has a LAN port
One can connect to the projector (Win 7 - All Programs > Accessories > Connect to a networked projector)
When I am connected via a wired LAN connection the PC will find the projector and connect with no problems.
When I connect via a wireless connection going through my WLC4136 it can not see the projector and will not connect.
Any advice on getting the network projector to be seen and connectable to on the wireless?
tom.mckim
Community Member
I fixed it.
Went to
Controller > General
Enabled Ethernet Multicast Mode
thank you for sharing the info.. you Rock
Surendra BG
