WLC5508 wireless clients can't see each other
ubuntu_guy
We've got our shiney new 5508 up and running, however the clients accociated to the AP cannot see each other. Where in the WLC can I allow the clients on a common AP to see/ping each other?
Thanks.
Kayle Miller
Level 7
Level 7
Richard,
     The first thing to check is under WLANS> WLAN  -> edit the SSID your clients are connected to and goto the advanced tab.
     Look for the drop-down box for P2P Blocking Action make sure this is set to Disabled. Any other setting prevents clients from talking to each other.
Hope this helps.... Please rate useful posts.
Kayle
Thank you very much, it did the trick
