WLC5670 - AP reboot issue
Alcides Miguel
Hi Folks,
I've a WLC 5670 with AIR-CAP3602I and sometimes all connected AP's restarts and I can't figure out why this is happening.
can someone help on this?
find the attached logs for more details
best regards,
Alcides
23 Replies 23
Pls attach below outputs from your 5760 & 5760 connected switch. If possible attach a diagram showing these connectivity.
show run
show spanning-tree summary
show spanning-tree root
show vtp status
Rasika
**** Pls rate all useful responses ***
Hi Rasika,
Thanks for your attention, I was out that's why the delay in response.
Another thing that I'm noting now is that the WLC is rebooting constantly, without a known reason
Find below the output:
WLC
#show spanning-tree summary
Switch is in rapid-pvst mode
Root bridge for: VLAN0004, VLAN0400-VLAN0402, VLAN0993
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0004                     0         0        0          1          1
VLAN0400                     0         0        0          1          1
VLAN0401                     0         0        0          1          1
VLAN0402                     0         0        0          1          1
VLAN0993                     0         0        0          1          1
#sh spanning-tree root
                                        Root    Hello Max Fwd
Vlan                   Root ID          Cost    Time  Age Dly  Root Port
VLAN0004         28676 c07b.bcd9.1a00         0    2   20  15
VLAN0400         29072 c07b.bcd9.1a00         0    2   20  15
VLAN0401         29073 c07b.bcd9.1a00         0    2   20  15
VLAN0402         29074 c07b.bcd9.1a00         0    2   20  15
VLAN0993         29665 c07b.bcd9.1a00         0    2   20  15
a#sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : c07b.bcd9.1a00
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Feature VLAN:
VTP Operating Mode                : Transparent
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 11
Configuration Revision            : 0
MD5 digest                        : 0x63 0x12 0x2F 0x4C 0x55 0x9C 0xB3 0xE7
                                    0x13 0xA7 0xE3 0x0F 0x6B 0xD2 0xC3 0x34
Catalyst 6509
#sh spanning-tree summary
Root bridge for: VLAN0002, VLAN0004-VLAN0005, VLAN0100-VLAN0101, VLAN0103
  VLAN0105-VLAN0111, VLAN0123-VLAN0126, VLAN0200-VLAN0201, VLAN0203
  VLAN0205-VLAN0211, VLAN0300-VLAN0306, VLAN0400-VLAN0402, VLAN0720
  VLAN0722-VLAN0723, VLAN0810, VLAN0813, VLAN0850, VLAN0900, VLAN0943
  VLAN0949, VLAN0953-VLAN0954, VLAN0991-VLAN0993
Portfast Edge BPDU Guard Default        is enabled
Portfast Edge BPDU Filter Default       is disabled
Platform PVST Simulation                is enabled
PVST Simulation Default                 is enabled but inactive in rapid-pvst mode
Bridge Assurance                        is enabled
Pathcost method used                    is long
VLAN0002                     0         0        0         15         15
VLAN0004                     0         0        0         16         16
VLAN0005                     0         0        0          1          1
VLAN0100                     0         0        0          6          6
VLAN0101                     0         0        0          1          1
VLAN0103                     0         0        0          1          1
VLAN0105                     0         0        0          1          1
VLAN0106                     0         0        0          1          1
VLAN0107                     0         0        0          1          1
VLAN0108                     0         0        0          1          1
VLAN0109                     0         0        0          1          1
VLAN0110                     0         0        0          1          1
VLAN0111                     0         0        0          1          1
VLAN0123                     0         0        0          1          1
VLAN0124                     0         0        0         15         15
VLAN0125                     0         0        0          1          1
VLAN0126                     0         0        0          5          5
VLAN0200                     0         0        0          6          6
VLAN0201                     0         0        0          1          1
VLAN0203                     0         0        0          1          1
VLAN0205                     0         0        0          1          1
VLAN0206                     0         0        0          1          1
VLAN0207                     0         0        0          1          1
VLAN0208                     0         0        0          1          1
VLAN0209                     0         0        0          1          1
VLAN0210                     0         0        0          1          1
VLAN0211                     0         0        0          1          1
VLAN0300                     0         0        0          6          6
VLAN0301                     0         0        0          1          1
VLAN0302                     0         0        0          1          1
VLAN0303                     0         0        0          2          2
VLAN0304                     0         0        0          2          2
VLAN0305                     0         0        0          2          2
VLAN0306                     0         0        0          1          1
VLAN0400                     0         0        0          1          1
VLAN0401                     0         0        0          1          1
VLAN0402                     0         0        0          1          1
VLAN0720                     0         0        0          4          4
VLAN0722                     0         0        0          4          4
VLAN0723                     0         0        0          4          4
VLAN0810                     0         0        0          5          5
VLAN0813                     0         0        0          5          5
VLAN0850                     0         0        0          1          1
VLAN0900                     0         0        0          1          1
VLAN0943                     0         0        0          5          5
VLAN0949                     0         0        0          5          5
VLAN0953                     0         0        0          5          5
VLAN0954                     0         0        0          1          1
VLAN0991                     0         0        0          2          2
VLAN0992                     0         0        0          1          1
VLAN0993                     0         0        0          2          2
51 vlans                     0         0        0        147        147
ACFINSWCSWP01a#sh spanning-tree root
                                        Root Hello Max Fwd
VLAN0002         24578 d0c7.89a8.3780         0    2   20  15
VLAN0004         24580 d0c7.89a8.3780         0    2   20  15
VLAN0005         24581 d0c7.89a8.3780         0    2   20  15
VLAN0100         24676 d0c7.89a8.3780         0    2   20  15
VLAN0101         24677 d0c7.89a8.3780         0    2   20  15
VLAN0103         24679 d0c7.89a8.3780         0    2   20  15
VLAN0105         24681 d0c7.89a8.3780         0    2   20  15
VLAN0106         24682 d0c7.89a8.3780         0    2   20  15
VLAN0107         24683 d0c7.89a8.3780         0    2   20  15
VLAN0108         24684 d0c7.89a8.3780         0    2   20  15
VLAN0109         24685 d0c7.89a8.3780         0    2   20  15
VLAN0110         24686 d0c7.89a8.3780         0    2   20  15
VLAN0111         24687 d0c7.89a8.3780         0    2   20  15
VLAN0123         24699 d0c7.89a8.3780         0    2   20  15
VLAN0124         24700 d0c7.89a8.3780         0    2   20  15
VLAN0125         24701 d0c7.89a8.3780         0    2   20  15
VLAN0126         24702 d0c7.89a8.3780         0    2   20  15
VLAN0200         24776 d0c7.89a8.3780         0    2   20  15
VLAN0201         24777 d0c7.89a8.3780         0    2   20  15
VLAN0203         24779 d0c7.89a8.3780         0    2   20  15
VLAN0205         24781 d0c7.89a8.3780         0    2   20  15
VLAN0206         24782 d0c7.89a8.3780         0    2   20  15
VLAN0207         24783 d0c7.89a8.3780         0    2   20  15
VLAN0208         24784 d0c7.89a8.3780         0    2   20  15
VLAN0209         24785 d0c7.89a8.3780         0    2   20  15
VLAN0210         24786 d0c7.89a8.3780         0    2   20  15
VLAN0211         24787 d0c7.89a8.3780         0    2   20  15
VLAN0300         24876 d0c7.89a8.3780         0    2   20  15
VLAN0301         24877 d0c7.89a8.3780         0    2   20  15
VLAN0302         24878 d0c7.89a8.3780         0    2   20  15
VLAN0303         24879 d0c7.89a8.3780         0    2   20  15
VLAN0304         24880 d0c7.89a8.3780         0    2   20  15
VLAN0305         24881 d0c7.89a8.3780         0    2   20  15
VLAN0306         24882 d0c7.89a8.3780         0    2   20  15
VLAN0400         24976 d0c7.89a8.3780         0    2   20  15
VLAN0401         24977 d0c7.89a8.3780         0    2   20  15
VLAN0402         24978 d0c7.89a8.3780         0    2   20  15
VLAN0720         25296 d0c7.89a8.3780         0    2   20  15
VLAN0722         25298 d0c7.89a8.3780         0    2   20  15
VLAN0723         25299 d0c7.89a8.3780         0    2   20  15
VLAN0810         25386 d0c7.89a8.3780         0    2   20  15
VLAN0813         25389 d0c7.89a8.3780         0    2   20  15
VLAN0850         25426 d0c7.89a8.3780         0    2   20  15
                                        Root Hello Max Fwd
VLAN0900         25476 d0c7.89a8.3780         0    2   20  15
VLAN0943         25519 d0c7.89a8.3780         0    2   20  15
VLAN0949         25525 d0c7.89a8.3780         0    2   20  15
VLAN0953         25529 d0c7.89a8.3780         0    2   20  15
VLAN0954         25530 d0c7.89a8.3780         0    2   20  15
VLAN0991         25567 d0c7.89a8.3780         0    2   20  15
VLAN0992         25568 d0c7.89a8.3780         0    2   20  15
VLAN0993         25569 d0c7.89a8.3780         0    2   20  15
#sh vtp status
VTP Version                     : 3 (capable)
Configuration Revision          : 66
Number of existing VLANs        : 63
VTP Operating Mode              : Server
VTP Domain Name                 : DC
VTP Pruning Mode                : Enabled (Operationally Enabled)
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Enabled
MD5 digest                      : 0x29 0xAC 0xB4 0xFC 0x12 0xA1 0xF4 0xFE
Configuration last modified by 10.16.126.1 at 12-18-14 17:28:23
Local updater ID is 10.16.126.1 on interface Vl2 (lowest numbered VLAN interface found)
VTP version running             : 2
Not sure what IOS-XE code you are running. I am running a 5760 on IOS-XE 3.6.1E (more than 6 months) & did not have any reboot issue.
If you willing to do an upgrade I would suggest to move this code & let's see. We need to fix one issue at a time (I think rebooting WLC is more critical)
Rasika
**** Pls rate all useful responses ****
I've installed the version that you have mentioned and I'll wait to see if the same issue will rise again.
Best Regards,
Alcides
Hi Rasika,
I've installed the new version, now I'm with
Switch Ports Model              SW Version        SW Image              Mode
*    1 6     AIR-CT5760         03.06.01E         ct5760-ipservicesk9   INSTALL
and with this version I'm still having the reboot issue,
where should I go from now?
Best regards,
Alcides
Open a TAC case.  My peer mentioned to me that two of his clients had the same issue and had the unit RMA'd.
-Scott
-Scott
BPDU guard????  If you have BPDU Guard you've got a lot of problems!
Port error-disable due BPDU Guard needs to be investigated as this is a Layer 1 issue.  Whenever I have a BPDU Guard fault on a fibre optic link, it means there is a potential threat that you've got a faulty fibre optic point-to-point link.
Treat BPDU Guard as a friend and not an enemy.  In medium- to large-scale deployment, BPDU Guard can be a saviour from network from crashing.
Let's get down to business.
Error is telling us that both TenGigEthernet interface had BPDU guard error.  What I'd like to know is this:  Is BPDU Guard (aggressive) enabled at BOTH SIDES?   The most common cause of this error is when BPDU Guard is enabled on one side but not on the remote end switch.
Joseph Vasanth Louis
Hi Alcides,
are these AP's rebooting randomly or do they have a pattern?
figure out one AP which is doing this and if it is quite often, telnet to the ap, enable
"debug capwap client events"
"debug capwap client error"
once the ap comes back up again, telnet back again, and do a sh logging on the ap. that should give you an idea of why the ap rebooted.
-Joseph
mohanak
Contact TAC for further assistance.
BUG CSCus05234
Error Message    AUTHMGR-4-UNAUTH_MOVE, MSGDEF_LIMIT_MEDIUM: [chars] MAC address
([enet]) from [chars] to [chars]
Explanation    There was an authenticated move on the old IDB. The first [chars] is slow or fast, the second [chars] is the source interface name, the third [chars] is the destination interface name, and [enet] is the MAC address.
Recommended Action    No action is required.
