WLC9800-L-F Tengiga ports not working
I have the following problem, I have a 9800L-F WLC, and I want to make a portchannel (LAG) with the fiber interfaces, it configures successfully, but I have no traffic through it. I don't see MAC either through this portchannel.
The WLC is using SFP-SX-MMD interfaces. Does anyone know why it doesn't work???
IOS-XE Version 17.3.5
21 Replies 21
Done, and nothing change.
I see some case in nexus with SFP and the issue was the auto negotiation, can you manually set the duplex and speed.
Thanks, This is the solution.
Regards.
For anybody else reading this thread - just to clarify what I believe the actual solution was:- on the TenGig port you must configure
"no negotiation auto".
My colleague was caught by this on 9800-80 last week when configuring the WLC manually from new without using a tested/working template.  It does actually tell you in the logs if you bother to look ...
*May 30 12:51:39.641: %IOSXE_EPA-3-AUTONEG_CFG_ERR: interface TenGigabitEthernet0/0/0 autoneg state 'negotiation auto' is incompatible with transciever. Remove 'negotiation auto' to allow the transceiver.
*May 30 12:51:39.642: %IOSXE_EPA-3-XCVR_PROHIBIT: Transceiver is prohibited to come online for interface TenGigabitEthernet0/0/0
*May 30 12:51:39.642: BUILT-IN-6X10G/2X1G[0/0] : XCVR prohibited on port TenGigabitEthernet0/0/0, epa_name=BUILT-IN-6X10G/2X1G, if_id=0/0/0, xcvr_speed=10000000, admin_state=UNSHUT
But the output on the interface is very misleading:
9800#sh int Te0/0/0 transceiver
The transceiver in slot 0 subslot 0 port 0 has been disabled because it is not supported by this card.
Leo Laohoo
Please post the complete output to the command "sh platform".
Hi Leo,
ILC-WLC-01#sh platform
Chassis type: C9800-L-F-K9
Slot Type State Insert time (ago)
0 C9800-L-F-K9 ok 01:53:48
0/0 BUILT-IN-4x2_5GE ok 01:52:00
0/1 BUILT-IN-2x10GE-F ok 01:52:00
R0 C9800-L-F-K9 ok, active 01:53:48
F0 C9800-L-F-K9 ok, active 01:53:48
P0 PWR-12V ok 01:53:27
P1 C9800-L-F-K9-FAN ok 01:53:27
Slot CPLD Version Firmware Version
0 19050918 16.12(3r)
R0 19050918 16.12(3r)
F0 19050918 16.12(3r)
ILC-WLC-01#
Regards.
Rich R
Have you upgraded the ethernet PHY as per https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_upgrade_fpga_c9800.html#id_132215 ? (3 bug fixes)
https://software.cisco.com/download/home/286321399/type/283425232/release/17.3.2
