WLC9800CL
Allan001
Level 2
Level 2
Good day all,
My name is Allan. I want some help configuring WLC-9800-CL HA. The controllers are already up, and I can access them on the ESXi server. The main issue is how to add three departments so that they can access Wi-Fi using different SSIDs. I have three departments listed below.
HR > 10.10.x.x/24 - VLAN 3
Finance >172.16.x.x/24 - VLAN 4
Admin > 172.16.x.x/24 - VLAN 2
Here is my thinking, I will create three WLANs in the controller with their respective SSIDs. In the controller, again configure three SVIs 10.10.x.254, 172.16.x.254, and 172.16.x.254.
After that, I will create static or default routes for each subnet, pointing to the gateway. Then Configure Gi2 of the controllers as a trunk and allow the three VLANs.
Then on the Core Switch, where I have the SVIs for these Subnets, I will add DHCP option 43 for each subnet.
Kindly advise if this is correct; if not, please point me in the right direction.
I really appreciate any help you can provide.
Allan
3 Accepted Solutions
balaji.bandi
You are in the right direction - Make sure Switch SVI as Gateway when you configure your DHCP for users' IP addresses.
configuring SSID PolicyTAG / SITE TAG / RF TAG   - if you did not come across this before?
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213911-understand-catalyst-9800-wireless-contro.html
BB
Good day, Rich,
Thank you so much for the info provided. I have taken note of your advice!
Thank you!
Scott Fella
@Allan001 do you happen to have a radius server like Cisco ISE or something else?  You might be able to just create your vlans, but then have one SSID and then depending on the OU the user belongs to, you can define the vlan.  This is assuming you are using 802.1x.
-Scott
10 Replies 10
balaji.bandi
BB
Hi Balaji,
Thank you so much for getting back to me so quickly. I will go through the URL provided; you are a lifesaver. If I am stuck somewhere, I will respond to this thread again.
Thank you!
Allan001
No worries, thanks for sharing your feedback. you should be good...
make sure if you doing anchoring/mobility , MAC Address should be same for HA Active and standby (if not when it failover mobility will not work)
BB
Mark Elsen
  - Also note that  before  production use , during and or later you can always have a checkup  of the  WLC-9800-CL HA   configuration with the CLI command : show  tech   wireless , (on the current master) have the output analyzed by  https://cway.cisco.com/tools/WirelessAnalyzer/  , please note do not use classical show tech-support (short version) , use the command denoted in green for Wireless Analyzer.              This procedure is strongly advised.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi, Marce 1000,
Thank you very much. I will test with the command " show tech wireless".
Much appreciated.
Allan001
Hi MArce1000,
Thank you very much. I will test with the "show tech wireless" command in
green.
Much appreciated.
Allan001
Rich R
Just one comment to add:
As per 9800 best practices guide (link in my signature below) it is not recommended to configure SVI on 9800 except where specifically required for specific features which only work with SVI on WLC.  You should simply be bridging the WLAN traffic to the VLAN with the SVIs on your switch.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Good day, Rich,
Thank you!
Scott Fella
-Scott
Hi Scott,
Thank you so much for the technical advice. Unfortunately, we do not have ISE. We are using a different FW. So many solutions from the community team. Thank you!
Allan001
