06-24-2025 05:02 AM
Hi Team,
i have an WLC9800L on VM . I try to discover my AP 3802I into it. but its not be discover. AP Light status is blinking red, blue and green. According to my experience we just need to power up AP and then it will discover on WLC. Please assist me i am in trouble from last week..
06-24-2025 08:21 AM
I think you might be having a confusion-you can not install a 9800-L-C in vm..i guess you are referring 9800-CL. please share-
‘show tech wireless’ from wlc
show power inline <ap interface> from switch
show cdp neighbor <ap interface> detail from switch
06-25-2025 05:43 AM
Did you remember to configure the Wireless Management Interface and certificate @hamza-ali ?
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#Configurationfilemanagement - see the section containing "It needs a Self Signed Certificate (SSC)"
And check your WLC config using the Config Analyzer - link below. You must use the output from "show tech wireless" (not "show tech"). This will highlight many common mistakes and best practices.
