WLCCA
CChris91
Visitor
Just came across this tool but having a few issues. I'm a newbie to all this but I've followed the instructions but I'm receiving a "Controller information not found in selected file. Please load the output of shrun-config, with paging disable for best results".
All I've done at this point is uploaded the running config via the Cisco 5508 WLC GUI, to a TFTP server in a .txt file.
I then try to open the config file through WLCCA and get this error. I'm probably doing something incredibly stupid or missing an obvious step. Can anyone help?!
Thanks!
Divya
Level 6
Level 6
Hi Chris,
Do a SSH/Telnet session using WLC mgmt IP address & log the session.
run the commands:
config paging disable
show run-config
config paging enable
Refer this link: https://supportforums.cisco.com/t5/wireless-mobility-documents/wlc-config-analyzer-how-to-load-a-file/ta-p/3115077
Divya
