WLSE and ACS
harrisn
When I configure my WLSE server (2.5) with an ACS and add the WLSE server TO the ACS server I get the message:
Radius server is not available
in the faults on WLSE and get the message:
"Invalid messsage authenticator in eap request"
in the ACS log.
Any suggestions
rmushtaq
Level 8
Level 8
See Table 2-3 Server Faults: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cwparent/cw_1105/wlse/2_5/ts_gd/faults.htm#1029186 for details and recommended action on this fault in WLSE. You need to add WLSE as a client in your ACS server. After you add AAA servers to the WLSE, the WLSE automatically performs periodic logins on each server to monitor the server's response time and availability and
displays this information under Reports > Trends.
minie
Level 4
Level 4
That error message is misleading. It indicates that you did not configure correct secret in WLSE under "devices > discover > AAA server".
In addition, also make sure you have created WLSE as NAS on ACS and authentication using "RADIUS (Cisco Aironet)"
