WLSE and Switch portIfIndex
kevinchan
When an AP is discovered, WLSE stores SwitchIP, portIfIndex, portIndex, portModuleIndex pair for the AP. However, if the switch is rebooted and portIfINdex is changed, WLSE doesn't recognize the ifIndex has changed and reported the AP is down.
Any thought?
s-doyle
Level 3
Level 3
I'm pretty sure I've seen some issues in bug toolkit about this. You should check that out.
