WLSE: Initial console port configuration
colin.lynch
Level 3
Level 3
Hi Hopfully not to dumb a question:
I am doing an Install and have a WLSE 1130 and I can not get any connection to the console to do the initial setup.
I have tried 96,8,1,n and 115200,8,1,n
I have been config'ing the ACS engine fine so I know my console is OK.
I just get a flashing green LED on the front, no network LED although it is connected.
Is it somthing stupid I'm doing, or is my WLSE DOA.
Colin
colin.lynch
Level 3
Level 3
Don't worry, I found somthing called "the on button"
I'll go and commit ritual suicide.
At least it's yopu guys thinking I'm a pleb and not TAC. 🙂
Shamfully
John Smith
rmushtaq
Level 11
Level 11
Use Windows Hyper Terminal. Setting need to be baud=9600 and the rest should be default. Make sure that you connect to the serial port located at the back of the WLSE.
