A9K-4HG-FLEX-SE vs A9K-4HG-FLEX-FC
malik.naeem
What is the difference between the SE and FC versions of A9K-4HG-FLEX?
Does A9K-4HG-FLEX-FC support the BNG features? And is it compatible with A9k-RSP5-SE?
tkarnani
the cards should be the same, -FC is flexible consumption which is licensed based documented here
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-741260.html
these are lightspeed based line cards, they support bng ; please be aware of scale/limitations listed here
https://xrdocs.io/asr9k/tutorials/asr-9000-bng-scale-best-practices/
malik.naeem
Thanks for your response.
Can we get the maximum number of Dual-Stack PPPoE sessions supported on A9K-4HG-FLEX with A9k-RSP5-SE on ASR9006?
