A9K MOD80 Cannot Power up
HI Experts
I am meeting a strange issue of ASR9K MOD80. This MOD80 Card cannot power up, and always output log as below:
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:MBI-RUNNING
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_KERNEL_DUMP_EVENT : Node 0/1/CPU0 indicates it is doing a kernel dump.
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:IOS XR FAILURE
shelfmgr[385]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-MOD80-SE state:BRINGDOWN
invmgr[249]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/CPU0, state: BRINGDOWN
canb-server[151]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/1/CPU0 , Power Cycle (0x05000000)
I have installed the Card to another A9K ( which version is same as the A9K) , and the MOD80 card can boot up and IOS XR RUN.
Did you have occur this issue ? Please help me to check it. many thks.
Attachment logging after MOD80 OIR collect..
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
15 Replies 15
@DUNGThanks for the case you mentioned ,I also try to switchover the RSP ,and OIR line card ,then the issue have been resloved..
